Canon I-SENSYS LBP6030W Mono Laser Printer
Quicklinx: B40DWS00 Mfr#: 8468B019
  • Windows 8.1 (32/64 bits)
  • Windows 8 (32/64 bits)
Enjoy the compact Wi-Fi mono laser printer for easy network and mobile printing. Network and mobile ready with automatic 2-sided printing and a host of energy and time-saving features, this space saving Wi-Fi mono laser printer is ideal for any small or home office.
  • Space saving, Wi-Fi mono laser printer
    With wireless, Ethernet and mobile connectivity, plus automatic 2-sided printing, this fast, compact and energy efficient mono laser Wi-Fi printer is perfectly suited for small or home offices and fits neatly on any size desk.
  • Wi-Fi, network and mobile ready
    Print seamlessly the way you want using this Wi-Fi, network and mobile ready device. Connecting it to your wireless network is effortless - just push the Wi-Fi key on the printer and you’re ready to go.
  • Fast, productive performance
    Meeting deadlines is easy thanks to impressive laser print speeds of 25ppm and Canon’s Quick First-Print technologies, which ensure speedy recovery from sleep mode. This device springs into action the moment you need it with a fast warm-up time of several seconds from power on plus a First Print Out Time (FPOT).
  • Automatic 2-sided printing
    Save money on paper and add an extra level of professionalism to your business documents with automatic 2-sided printing.
  • Exceptional laser quality
    Enjoy the sharp, crisp text and highly detailed graphics thanks to a print resolution of up to 1200 x 1200 dpi with Automatic Image Refinement.
  • Energy efficient
    Thanks to Canon’s On Demand fixing technology this printer offers real energy efficiency, using as little as 0.9 Watts in sleep mode with virtually no warm up time. A convenient front power switch makes it easy to turn off, cutting energy costs and reducing its environmental impact even further.
  • Quiet operation
    Thanks to Canon’s unique engine design, the printer is silent in standby mode and exceptionally quiet during operation – so you can focus on your work without distraction.
Canon i-SENSYS LBP6230dw - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
7 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 25 ppm - B/W - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Image Enhancement Technology
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
RAM Installed (Max)
64 MB
Language Simulation
Canon Ultra Fast Rendering (UFRII LT)
Media Type
Envelopes, transparencies, labels, plain paper, index cards, heavy-weight paper
Total Media Capacity
250 sheets
Media Handling
250-sheet multipurpose tray, 1-sheet manual tray
Monthly Duty Cycle (max)
8000 pages
Linux, Apple MacOS X 10.6 or later, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition
37.9 cm x 29.3 cm x 24.3 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Wireless
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
6 sec
Language Simulation
Media Handling
RAM
RAM Installed (Max)
64 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Duty Cycle
8000 pages
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 900 pages ISO/IEC 19752 - Canon 726 Starter
Mobile Printing
Power supply - internal
Frequency Required
50/60 Hz
1100 Watt
Power Consumption Stand by
2.2 Watt
Power Consumption Sleep
1.6 Watt
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
52 dB
37.9 cm
29.3 cm
24.3 cm
7 kg
B40D C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
