Enjoy the compact Wi-Fi mono laser printer for easy network and mobile printing. Network and mobile ready with automatic 2-sided printing and a host of energy and time-saving features, this space saving Wi-Fi mono laser printer is ideal for any small or home office.
Space saving, Wi-Fi mono laser printer
With wireless, Ethernet and mobile connectivity, plus automatic 2-sided printing, this fast, compact and energy efficient mono laser Wi-Fi printer is perfectly suited for small or home offices and fits neatly on any size desk. -
Wi-Fi, network and mobile ready
Print seamlessly the way you want using this Wi-Fi, network and mobile ready device. Connecting it to your wireless network is effortless - just push the Wi-Fi key on the printer and you’re ready to go. -
Fast, productive performance
Meeting deadlines is easy thanks to impressive laser print speeds of 25ppm and Canon’s Quick First-Print technologies, which ensure speedy recovery from sleep mode. This device springs into action the moment you need it with a fast warm-up time of several seconds from power on plus a First Print Out Time (FPOT). -
Automatic 2-sided printing
Save money on paper and add an extra level of professionalism to your business documents with automatic 2-sided printing. -
Exceptional laser quality
Enjoy the sharp, crisp text and highly detailed graphics thanks to a print resolution of up to 1200 x 1200 dpi with Automatic Image Refinement. -
Energy efficient
Thanks to Canon’s On Demand fixing technology this printer offers real energy efficiency, using as little as 0.9 Watts in sleep mode with virtually no warm up time. A convenient front power switch makes it easy to turn off, cutting energy costs and reducing its environmental impact even further. -
Quiet operation
Thanks to Canon’s unique engine design, the printer is silent in standby mode and exceptionally quiet during operation – so you can focus on your work without distraction.
- Canon i-SENSYS LBP6230dw - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 7 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 25 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Image Enhancement Technology
- Automatic Image Refinement
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- RAM Installed (Max)
- 64 MB
- Language Simulation
- Canon Ultra Fast Rendering (UFRII LT)
- Media Type
- Envelopes, transparencies, labels, plain paper, index cards, heavy-weight paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet multipurpose tray, 1-sheet manual tray
- Monthly Duty Cycle (max)
- 8000 pages
- System Requirements
- Linux, Apple MacOS X 10.6 or later, Android, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Apple iOS, Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition
- 37.9 cm x 29.3 cm x 24.3 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 6 sec
- Media Handling
RAM
- 64 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 8000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 900 pages ISO/IEC 19752 - Canon 726 Starter
- Mobile Printing
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1100 Watt
- Power Consumption Stand by
- 2.2 Watt
- Power Consumption Sleep
- 1.6 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 52 dB
- 37.9 cm
- 29.3 cm
- 24.3 cm
- 7 kg
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £4.16 |
