An affordable, space saving mono laser printer designed for personal or small office use. Quiet, reliable and highly energy efficient with low power consumption it delivers fast, high quality prints.
- Affordable mono laser printer – ideal for a small or home office
- Fast, high quality mono prints at 18 pages per minute
- No waiting for prints with Quick First Print
- Stylish, space saving design to enhance any desktop
- Enjoy class leading energy efficiency
Space saving, mono laser printer
Designed to fit comfortably on the desk, this fast, compact and affordable mono laser printer is perfect for personal and small office use. Its sleek, space-saving design in a stylish black colour includes a retractable paper tray cover and keeps dimensions to a mere 364 x 249 x 198 mm (W x D x H).
Fast, productive performance
The i-SENSYS LBP6030B springs into the action the moment you need it thanks to Canon’s Quick First-Print technologies, which ensure quick recovery from sleep mode. With a First Print Out Time (FPOT) of just 7.8 seconds and professional laser print speeds of 18 ppm there’s no waiting around for your prints – so you can quickly get back to what’s important.
Designed to fit comfortably on the desk, this fast, compact and affordable mono laser printer is perfect for personal and small office use. Its sleek, space-saving design includes a retractable paper tray cover. -
The i-SENSYS LBP6030B springs into the action the moment you need it thanks to Canon’s Quick First-Print technologies, which ensure quick recovery from sleep mode. With a First Print Out Time (FPOT) of just 7.8 seconds and professional laser print speeds of 18 ppm there’s no waiting around for your prints – so you can quickly get back to what’s important. -
Exceptional laser quality
Enjoy the sharpest, crispest text and most detailed graphics thanks to high print resolution with Automatic Image Refinement. The MS (Magnetic Spherical) toner has been specifically developed to deliver optimum results print after print. -
Energy efficient
Thanks to Canon’s On Demand fixing technology this energy efficient printer uses only 0.8 watts in sleep mode and there’s virtually no warm up time. A convenient front power switch makes it easy to turn off, cutting energy costs and reducing its environmental impact even further. -
Quiet operation
Thanks to Canon’s engine design, the i-SENSYS LBP6030B is silent in standby mode and exceptionally quiet during operation – so you can focus on your work without distraction. -
All-in-One cartridge
The recyclable All-in-One cartridge ensures maintenance-free operation and reliable high quality output. The Authentic Canon Laser Cartridge contains toner, drum and cleaning units and can be replaced in seconds without any fuss or mess.
- Canon i-SENSYS LBP6030B - printer - B/W - laser
- Printer Type
- Personal printer - laser - B/W
- 5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 188 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 18 ppm - B/W - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 2400 x 600 dpi
- Image Enhancement Technology
- Automatic Image Refinement
- Interface
- USB 2.0
- RAM Installed (Max)
- 32 MB
- Language Simulation
- Canon Ultra Fast Rendering (UFRII LT)
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy paper
- Total Media Capacity
- 150 sheets
- Media Handling
- 150-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 5000 pages
- Power
- AC 220-240 V
- System Requirements
- Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2 x64 Edition
- 36.4 cm x 24.9 cm x 19.9 cm
- Printer Type
- Personal printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wired
- Interface
- USB 2.0
- 2400 x 600 dpi
- First Print Out Time B/W
- 7.8 sec
- Media Handling
RAM
- 32 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 188 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 188 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 150 sheets
- Media Feeders
- 1 x automatic - 150 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 5000 pages
- Connections
- 1 x USB 2.0 - 4 pin USB Type B
- Consumables Included
- 2 x toner cartridge (black) - up to 1600 pages ISO/IEC 19752 - Canon 725
- Power Device
- Power supply - internal
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 870 Watt
- Power Consumption Stand by
- 1.8 Watt
- Power Consumption Sleep
- 0.8 Watt
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 49.2 dBA
- 36.4 cm
- 24.9 cm
- 19.9 cm
- 5 kg
Canon 725 BLACK TONER | In Stock | £50.99 |
