Canon i-SENSYS LBP352x A4 Mono Laser Printer
Quicklinx: CJMTWS00 Mfr#: 0562C016
A fast black-and-white laser printer in a compact form factor with flexible media handling capabilities, making it ideal for demanding environments that need versatility and speed.
Benefits
  • Prints at a rapid 62ppm
  • Highly productive with an expandable paper capacity up to 3,600 pages and a range of optional cassette configurations
  • Suitable for all environments thanks to its small footprint
  • Print from smartphones and tablets with support for mobile printing
  • Efficient to run, using high-capacity Canon toner cartridges
  • Easily manage as part of your network
  • Optional secure printing and storage
  • Simple double-sided printing to reduce waste and save costs
Take a more detailed look into the Canon i-SENSYS LBP352x
Fast and flexible printing-
With black-and-white printing at 62ppm and a choice of flexible configurations, the LBP352x is ideal for busy working environments that demand a reliable and versatile printer. A choice of up to four paper cassettes, plus an optional high-capacity paper deck, makes it an easily configurable and highly productive printer.
High-capacity in a small footprint-
To be productive, you need a high-capacity printer, so that’s why the LBP352x has a large 600-page capacity as standard, expandable to 3,600 pages. A compact and capable office companion, this larger capacity still comes in a small package. There is also a high yield toner cartridge that allows you to print more pages before replacement, making you even more productive. Whatever the printing task, the LBP352x is built for versatility. From A5 to A4 double-sided documents, it’s ready to deliver in seconds.
Cloud and mobile printing-
Thanks to the LBP352x’s support for Apple AirPrint (iOS) and Mopria (Android), you can print easily from any compatible device. You can also benefit from more advanced features with the Canon PRINT Business app. For those using Google in the workplace, the LBP352x comes Google Cloud print-ready for seamless integration.
Smart networking and management capabilities-
The LBP352x is a superbly versatile addition to your printer fleet. Support for PCL5e/6 and Adobe PostScript printer languages enable hassle-free integration into managed network environments. The LBP352x is equally well-suited to managed print service environments and is compatible with Canon’s e-Maintenance remote service management system The LBP352x can also be integrated into Canon’s uniFLOW output management platform, bringing you the efficiency and security of My Print Anywhere plus the added benefits of accounting and cost recovery.
  • Fast and flexible printing
    With black-and-white printing at 62 ppm and a choice of flexible configurations, the LBP352x is ideal for busy working environments that demand a reliable and versatile printer. A choice of up to four paper cassettes makes it an easily configurable and highly productive printer.
  • High-capacity in a small footprint
    To be productive, you need a high-capacity printer, so that's why the LBP352x has a large 600-page capacity as standard, expandable to 3,600 pages. A compact and capable office companion, this larger capacity still comes in a small package. There is also a high yield toner cartridge that allows you to print more pages before replacement, making you even more productive. Whatever the printing task, the LBP352x is built for versatility. From A5 to A4 double-sided documents, it's ready to deliver in seconds.
Canon i-SENSYS LBP352x - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
26.2 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 62 ppm - B/W - A4 (210 x 297 mm) , Up to 41.4 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, USB host
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PCL 5E, PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF
Media Type
Envelopes, labels, plain paper, heavy-weight paper, cards
Total Media Capacity
600 sheets
Media Handling
500-sheet paper cassette, 100-sheet multipurpose tray
Monthly Duty Cycle (max)
280000 pages
Recommended Monthly Volume
5000 - 20000 pages
Print server
AC 230V
Linux, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Android, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10
41.5 cm x 52.9 cm x 43.8 cm
2 Years
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Status LCD
Wired
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
7 sec
Language Simulation
Fonts Included
93 x PCL , 136 x PostScript
Media Handling
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 199 g/m²
600 sheets
Media Feeders
1 x automatic - 500 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m²
Max Media Capacity
3600 sheets
Output Trays Capacity
600 sheets
Duty Cycle
280000 pages
5000 - 20000 pages
Print server
Security Protocols & Features
Secure Print
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - Canon 039
Power supply - internal
AC 230V
Frequency Required
50/60 Hz
1650 Watt
Power Consumption Stand by
19 Watt
Power Consumption Sleep
1.1 Watt
Software Included
Drivers & Utilities, Canon PRINT Business
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
57 dB
41.5 cm
52.9 cm
43.8 cm
26.2 kg
Service and Support
2 Years
