High-capacity printing ideal for productivity-focussed workplaces that need a flexible black-and-white laser printer.
Benefits
- Rapid printing at 55ppm
- Increased productivity with an expandable page capacity up to 3,600 with a range of optional cassette configurations
- Suitable for all environments thanks to a small footprint
- Print from smartphones and tablets with support for mobile printing
- Efficient to run, using high-capacity Canon toner cartridges
- Simple to manage as part of your network
- Optional secure printing and storage
- Easy double-sided printing to save costs and reduce waste
Fast and flexible printing-
With black-and-white printing at 55ppm, and a choice of flexible configurations, the LBP351x is ideal for busy working environments that demand a reliable and versatile printer. A choice of up to four paper cassettes, plus an optional high-capacity paper deck, makes it an easily configurable and highly productive printer.
Cloud and mobile printing-
Thanks to the LBP351x’s support for Apple AirPrint (iOS) and Mopria (Android), you can print easily from any compatible device. You can also benefit from more advanced features with the Canon PRINT Business app. For those using Google in the workplace, the LBP351x comes Google Cloud print-ready for seamless integration.
High-capacity in a small footprint-
To be productive, you need a high-capacity printer, so that’s why the LBP351x has a large 600-page capacity as standard, expandable to 3,600 pages. A compact and capable office companion, this larger capacity still comes in a small package. There is also a high yield toner cartridge that allows you to print more pages before replacement, making you even more productive. Whatever the printing task, the LBP351x is built for versatility. From A5 to A4 double-sided documents, it’s ready to deliver in seconds.
Smart networking and management capabilities-
The LBP351x is a superbly versatile addition to your printer fleet. Support for PCL5e/6 and Adobe PostScript printer languages enable hassle-free integration into managed network environments. The LBP351x is equally well-suited to managed print service environments and is compatible with Canon’s e-Maintenance remote service management system The LBP351x can also be integrated into Canon’s uniFLOW output management platform, bringing you the efficiency and security of My Print Anywhere plus the added benefits of accounting and cost recovery.
- Canon i-SENSYS LBP351x - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 26.2 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 55 ppm - B/W - A4 (210 x 297 mm) , Up to 36.5 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, USB host
- AirPrint Enabled
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PCL 5E, PostScript, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF
- Media Type
- Envelopes, labels, plain paper, heavy-weight paper, cards
- Total Media Capacity
- 600 sheets
- Media Handling
- 500-sheet paper cassette, 100-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 250000 pages
- Recommended Monthly Volume
- 3000 - 16000 pages
- Networking
- Print server
- Power
- AC 230V
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Android, Windows 8, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10
- 41.5 cm x 52.9 cm x 43.8 cm
- 2 Years
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- First Print Out Time B/W
- 7.2 sec
- Fonts Included
- 93 x PCL , 136 x PostScript
- Media Handling
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76 x 127 mm, Foolscap (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 199 g/m²
- 600 sheets
- Media Feeders
- 1 x automatic - 500 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , 1 x automatic - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m²
- Max Media Capacity
- 3600 sheets
- Output Trays Capacity
- 600 sheets
Duty Cycle
- 250000 pages
- Networking
- Print server
- Secure Print
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - Canon 039
- Power Device
- Power supply - internal
- Voltage Required
- AC 230V
- Frequency Required
- 50/60 Hz
- 1650 Watt
- Power Consumption Stand by
- 19 Watt
- Power Consumption Sleep
- 1.1 Watt
- Software Included
- Drivers & Utilities, Canon PRINT Business
- OS Required
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 56 dB
- 41.5 cm
- 52.9 cm
- 43.8 cm
- 26.2 kg
Service and Support
- 2 Years
Canon 039H High Yield Ink Cartridge - Black | In Stock | £182.17 |
