Create an effortless print experience with the i-SENSYS LBP240 Series. Embrace fast print speeds, robust security, and cloud connectivity to save time and resources and produce professional quality output.
Protect documents
360-degree security ensures complete document, device and network security. Security features include TLS1.3, Verify System at Startup, and secure PIN print on select models. -
Mobile printing
Conveniently print documents from your smartphone or tablet with the Canon PRINT Business app, or via AirPrint (iOS) and Mopria (Android). -
Boost productivity
Save valuable time with print speeds of 40 ppm, a warm-up time of 14 seconds and fast double sided printing. Quickly replace the All-in-One toner cartridge when needed to ensure minimum downtime. -
Save space
A compact design helps you easily place devices on desktops or counters, maximizing office space as a result.
 - Canon i-SENSYS LBP246dw - printer - B/W - laser
- Printer Type
 - Workgroup printer - laser - B/W
 - 9.5 kg
- Media Size Class
 - A4/Legal
- Max Media Size
 - Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
 - 76.2 mm x 127 mm
- Max Media Size (Custom)
 - 216 mm x 356 mm
- Print Speed
 - Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 65.4 ppm - B/W - A5 (148 x 210 mm) , Up to 33.6 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
 - 1200 x 1200 dpi
- Automatic Duplexing
- Interface
 - USB 2.0, Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
 - 1200 MHz
- RAM Installed (Max)
 - 1 GB
- Flash Memory Installed (Max)
 - 4 GB
- Language Simulation
 - PCL 5E, PostScript 3, PCL 6, Canon Ultra Fast Rendering (UFRII)
- Media Type
 - Envelopes, labels, plain paper, index cards, recycled paper, thin paper, postcards, heavy paper
- Total Media Capacity
 - 350 sheets
- Media Handling
 - 100-sheet multipurpose tray, 250-sheet paper cassette
- Monthly Duty Cycle (max)
 - 80000 pages
- Recommended Monthly Volume
 - 750 - 4000 pages
- Networking
 - Print server
- Power
 - AC 220-240 V
- System Requirements
 - Linux, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 10, Microsoft Windows Server 2016, Microsoft Windows Server 2019, Apple MacOS X 10.13 or later, Microsoft Windows Server 2022, Windows 11
 - 39.9 cm x 37.3 cm x 24.9 cm
- Printer Type
 - Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
 - Numeric key pad, 5 line LCD display, status LED
- Connectivity Technology
 - Wireless
- Interface
- AirPrint Enabled
 - 1200 x 1200 dpi
- First Print Out Time B/W
 - 5 sec
- Fonts Included
 - 45 x PCL , 136 x PostScript 3
- Media Handling
- Processor
 - 1200 MHz
RAM
 - 1 GB
Flash Memory
- Flash Memory
 - 4 GB
Media Handling
- Media Type
- Media Size Class
 - A4/Legal
- Max Media Size
 - 76.2 mm x 127 mm
 - 216 mm x 356 mm
- Media Sizes
 - ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm), A5 Landscape
- Envelope Sizes
 - International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
 - 60 g/m² - 199 g/m²
 - 350 sheets
- Media Feeders
 - Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m²
- Max Media Capacity
 - 900 sheets
- Output Trays Capacity
 - 150 sheets
Duty Cycle
 - 80000 pages
 - 750 - 4000 pages
- Networking
 - Print server
- Remote Management Protocol
 - SNMP 1, SNMP 3, HTTPS, IPPS, IPv4, IPv6
 - SSL, WEP, WPA-PSK, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering, WPA2-EAP, TLS 1.3 Encryption, WPA-EAP
- Connections
 - 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
 - Secure print
 - TLS v1.3
- Power Device
 - Power supply
- Voltage Required
 - AC 220-240 V
- Frequency Required
 - 50/60 Hz
 - 480 Watt
- Power Consumption Stand by
 - 6 Watt
- Power Consumption Sleep
 - 0.9 Watt
- Software Included
 - Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
 - 10 °C
 - 30 °C
 - 20 - 80% RH (non-condensing)
- Sound Emission (Operating)
 - 54 dB
 - 39.9 cm
 - 37.3 cm
 - 24.9 cm
 - 9.5 kg
