Create an effortless print experience with the i-SENSYS LBP240 Series. Embrace fast print speeds, robust security, and cloud connectivity to save time and resources and produce professional quality output.
Protect documents
360-degree security ensures complete document, device and network security. Security features include TLS1.3, Verify System at Startup, and secure PIN print on select models. -
Mobile printing
Conveniently print documents from your smartphone or tablet with the Canon PRINT Business app, or via AirPrint (iOS) and Mopria (Android). -
Boost productivity
Save valuable time with print speeds of 40 ppm, a warm-up time of 14 seconds and fast double sided printing. Quickly replace the All-in-One toner cartridge when needed to ensure minimum downtime. -
Save space
A compact design helps you easily place devices on desktops or counters, maximizing office space as a result.
- Canon i-SENSYS LBP246dw - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- A4 (210 x 297 mm), Legal (216 x 356 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 40 ppm - B/W - A4 (210 x 297 mm) , Up to 65.4 ppm - B/W - A5 (148 x 210 mm) , Up to 33.6 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 1200 MHz
- RAM Installed (Max)
- 1 GB
- Flash Memory Installed (Max)
- 4 GB
- Language Simulation
- Canon Ultra Fast Rendering (UFRII), PCL 5E, PCL 6, PostScript 3
- Media Type
- Plain paper, recycled paper, heavy paper, thin paper, labels, postcards, envelopes, index cards
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Power
- AC 220-240 V
- System Requirements
- Windows 11, Windows 10, Microsoft Windows Server 2022, Microsoft Windows Server 2019, Microsoft Windows Server 2016, Microsoft Windows Server 2012 R2, Microsoft Windows Server 2012, Apple MacOS X 10.13 or later, Linux
- 39.9 cm x 37.3 cm x 24.9 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- 5 line LCD display, status LED, numeric key pad
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- First Print Out Time B/W
- 5 sec
- Fonts Included
- 45 x PCL , 136 x PostScript 3
- Media Handling
- Processor
- 1200 MHz
RAM
- 1 GB
Flash Memory
- Flash Memory
- 4 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- A4 (210 x 297 mm), A5 (148 x 210 mm), A5 Landscape, A6 (105 x 148 mm), B5 (176 x 250 mm), Legal (216 x 356 mm), ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), Statement (139.7 x 215.9 mm), Oficio (216 x 343 mm), Foolscap (216 x 343 mm), 76.2 x 127 mm
- Envelope Sizes
- Com-10 (105 x 241 mm), Monarch (98.4 x 190.5 mm), International C5 (162 x 229 mm), International DL (110 x 220 mm)
- Media Weight
- 60 g/m² - 199 g/m²
- 350 sheets
- Media Feeders
- Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 199 g/m²
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 3, IPv4, IPv6, HTTPS, IPPS
- TLS 1.3 Encryption, IPsec, IP filtering, MAC address filtering, 802.1x, SSL, WEP, WPA-PSK, WPA2-PSK, WPA-EAP, WPA2-EAP, TKIP, AES
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Secure print
- TLS v1.3
- Power Device
- Power supply
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 480 watt
- Power Consumption Stand by
- 6 watt
- Power Consumption Sleep
- 0.9 watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- ENERGY STAR
- 10 °C
- 30 °C
- 20 - 80% RH (non-condensing)
- Sound Emission (Operating)
- 54 dB
- 39.9 cm
- 37.3 cm
- 24.9 cm
- 9.5 kg
