Fast, reliable black and white single-function laser printers with enhanced mobile connectivity.
Transform your black and white printing with advanced productivity
Mono single-function laser printers in the Canon i-SENSYS LBP230 Series are designed to keep you securely connected, with speed, reliability, and mobile connectivity for efficient and productive printing.
Boost workflow efficiency
33-38ppm A4 black and white print speeds in the Canon i-SENSYS LBP230 Series deliver maximum productivity, with double-sided printing as standard.
Stay connected wherever you are
Mobile connectivity means you can conveniently print from wherever you are – either through the Canon PRINT Business app, AirPrint (iOS) or Mopria (Android).
33-38ppm A4 black and white print speeds in the Canon i-SENSYS LBP230 Series deliver maximum productivity, with double-sided printing as standard. -
Protect documents and devices
Secure PIN functionality prevents sensitive documents being automatically released. -
Mobile connectivity means you can conveniently print from wherever you are - either through the Canon PRINT Business app, AirPrint (iOS) or Mopria (Android).
- Canon i-SENSYS LBP233dw - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 52.5 ppm - B/W - A5 (148 x 210 mm) , Up to 28.7 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 800 MHz
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PCL 5E, PCL 6, Canon Ultra Fast Rendering (UFRII)
- Media Type
- Envelopes, labels, plain paper, index cards, recycled paper, thin paper, label paper, postcards, coloured paper
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- Power
- AC 220-240 V
- System Requirements
- Linux, Windows 8.1, Windows 10, Apple MacOS X 10.11 or later, Microsoft Windows Server 2022, Windows 11
- 2-year warranty (France - 3 years with product registration)
- 40.1 cm x 37.3 cm x 25 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Numeric key pad, 5 line LCD display
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- First Print Out Time B/W
- 5.5 sec
- Fonts Included
- 45 x PCL
- Media Handling
- Processor
- 800 MHz
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 350 sheets
- Media Feeders
- Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Multi-purpose tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 900 sheets
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- 750 - 4000 pages
- Networking
- Print server
- Remote Management Protocol
- SNMP 1, SNMP 3, HTTPS, IPPS, IPv4, IPv6
- SSL, WEP, WPA-PSK, IPsec, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Access Point Mode
- TLS v1.3
- Power Device
- Power supply
- Voltage Required
- AC 220-240 V
- Frequency Required
- 50/60 Hz
- 1330 Watt
- Power Consumption Stand by
- 9 Watt
- Power Consumption Sleep
- 0.9 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Limited warranty - 2 years
- Regional Warranty Exceptions
- France - 3 years with product registration
- 10 °C
- 30 °C
- 20 - 80% RH (non-condensing)
- Sound Emission (Operating)
- 54 dB
- 40.1 cm
- 37.3 cm
- 25 cm
- 9.5 kg
