Canon i-SENSYS LBP228x Mono Laser Printer
Quicklinx: FRZ5WS00 Mfr#: 3516C017
Take your business to the next level with a fast and reliable laser printer. Print speeds of 38ppm for A4 ensure maximum efficiency, as do personalized on-screen controls. Greater security is also assured by PIN release and user authentication.
A true tool for modern businesses, LBP228x not only has superior print speeds but also comes with an upgraded Application Library for customized controls and better cost-saving and security measures via the Universal Login Manager (ULM).
  • Efficient productivity
    With a first print out time of just 5.5 seconds and a maximum printing speed of 38 ppm for A4 documents, this printer is engineered for efficiency. Its automatic duplexing feature further enhances productivity by facilitating easy double-sided printing.
  • High-quality output
    Achieve professional-grade monochrome prints with a maximum resolution of 1200 x 1200 DPI, ensuring crisp and clear text on every page. Whether it's important documents or client presentations, the output quality meets the high standards required.
  • Versatile media handling
    Designed to support a wide range of media sizes from A5 to Legal and types including envelopes, labels, plain paper, postcards, and recycled paper. The printer's flexible media handling capabilities make it suitable for various printing needs.
  • Advanced connectivity
    Equipped with Gigabit LAN, USB 2.0, and Wi-Fi(n) interfaces, along with support for Apple AirPrint, Google Cloud Print, and Mopria Print Service, this printer offers seamless connectivity options for both wired and wireless printing environments.
  • Robust security features
    Secure Print functionality ensures that sensitive documents are kept confidential, making this printer a reliable choice for environments where document security is paramount.
Canon i-SENSYS LBP228x - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.9 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 38 ppm - B/W - A4 (210 x 297 mm) , Up to 63.1 ppm - B/W - A5 (148 x 210 mm) , Up to 31.9 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PCL 5E, PostScript 3, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
Media Type
Envelopes, labels, plain paper, recycled paper, thin paper, postcards
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
AC 230V
Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.9.5 or later, Microsoft Windows Server 2019, Apple macOS 10.14
43.8 cm x 37.3 cm x 31.2 cm
2-year Limited Warranty
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
5 inch LCD touch screen
Wireless
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
5.5 sec
Language Simulation
Fonts Included
93 x PCL , 136 x PostScript
Media Handling
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 163 g/m²
350 sheets
Media Feeders
Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 120 g/m² , Bypass tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
750 - 4000 pages
Print server
Security Protocols & Features
Secure Print
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 1500 pages
Power supply
AC 230V
Frequency Required
50/60 Hz
1330 Watt
Power Consumption Stand by
9 Watt
Power Consumption Sleep
0.9 Watt
Software Included
Drivers & Utilities, uniFLOW online, uniFLOW online Express
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
54 dB
43.8 cm
37.3 cm
31.2 cm
9.9 kg
FRZ5 Canon i-SENSYS 057 Toner Cartridge Black In Stock £84.06
FRZ5 Canon 3010C002 057H Black Toner Cartridge 10K Page In Stock £152.40
