The i-SENSYS LBP210 series are fast, double sided, A4 black and white printers engineered to enhance work flow and productivity, and cut costs. Delivering improved, high-quality results, they are ideal for SMEs.
- Save time with fast print speeds of up to 38ppm (LBP214dw/ LBP215x)
- High quality 1200 x 1200 dpi print resolution
- Easy operation with large colour touchscreen on LBP215x
- Compatible with AirPrint and Mopria for mobile connectivity
- Large storage with 1GB internal memory
- Secure PIN printing from mobile devices (LBP214dw/ LBP215x)
- Improved flexibility with varied media support; A4, A5,A6
- Quick and simple mobile connectivity via QR code (LBP215x)
- Application Library allowing automation, added shortcuts and a customised interface(LBP215x)
- Universal Login Manager function and uniFLOW ready (LBP215x)
Efficient productivity
With a robust monthly duty cycle of up to 80,000 pages and recommended monthly volume of 750 - 4,000 pages, the Canon i-SENSYS LBP212dw is designed to meet the demands of busy office environments. Its automatic duplexing feature enhances productivity by facilitating double-sided printing without manual intervention. -
High-quality printing
Achieve professional monochrome printing with a maximum resolution of 1200 x 1200 DPI. The Canon i-SENSYS LBP212dw ensures crisp, clear text and graphics for all your documents. -
Versatile connectivity
Offering both wired and wireless connectivity options, including Gigabit Ethernet, USB 2.0, and Wi-Fi, along with support for Apple AirPrint, Google Cloud Print, and Mopria Print Service, this printer provides the flexibility needed to support a variety of workplace setups and mobile printing needs.
- Canon i-SENSYS LBP212dw - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 9.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 215.9 mm x 355.6 mm
- Print Speed
- Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 52.5 ppm - B/W - A5 (148 x 210 mm) , Up to 26.4 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- RAM Installed (Max)
- 1 GB
- Language Simulation
- PCL 5E, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
- Media Type
- Envelopes, labels, plain paper, recycled paper, thin paper, postcards
- Total Media Capacity
- 350 sheets
- Media Handling
- 100-sheet multipurpose tray, 250-sheet paper cassette
- Monthly Duty Cycle (max)
- 80000 pages
- Recommended Monthly Volume
- 750 - 4000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Apple OS X 10.8.5 Mountain Lion or later, Microsoft Windows Server 2016
- 40.1 cm x 37.3 cm x 25 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Numeric key pad, LCD display
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 x 1200 dpi
- First Print Out Time B/W
- 5.5 sec
- Fonts Included
- 45 x PCL
- Media Handling
RAM
- 1 GB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 52 g/m² - 163 g/m²
- 350 sheets
- Media Feeders
- Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 120 g/m² , Bypass tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 163 g/m²
- Output Trays Capacity
- 150 sheets
Duty Cycle
- 80000 pages
- 750 - 4000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B ¦ 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1600 pages
- Power Device
- Power supply
- Frequency Required
- 50/60 Hz
- 1300 Watt
- Power Consumption Stand by
- 10 Watt
- Power Consumption Sleep
- 0.9 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 56 dB
- 40.1 cm
- 37.3 cm
- 25 cm
- 9.5 kg
