Canon i-SENSYS LBP212dw Mono Laser Printer
Quicklinx: DJNJWS00 Mfr#: 2221C019
The i-SENSYS LBP210 series are fast, double sided, A4 black and white printers engineered to enhance work flow and productivity, and cut costs. Delivering improved, high-quality results, they are ideal for SMEs.
  • Save time with fast print speeds of up to 38ppm (LBP214dw/ LBP215x)
  • High quality 1200 x 1200 dpi print resolution
  • Easy operation with large colour touchscreen on LBP215x
  • Compatible with AirPrint and Mopria for mobile connectivity
  • Large storage with 1GB internal memory
  • Secure PIN printing from mobile devices (LBP214dw/ LBP215x)
  • Improved flexibility with varied media support; A4, A5,A6
  • Quick and simple mobile connectivity via QR code (LBP215x)
  • Application Library allowing automation, added shortcuts and a customised interface(LBP215x)
  • Universal Login Manager function and uniFLOW ready (LBP215x)
  • Efficient productivity
    With a robust monthly duty cycle of up to 80,000 pages and recommended monthly volume of 750 - 4,000 pages, the Canon i-SENSYS LBP212dw is designed to meet the demands of busy office environments. Its automatic duplexing feature enhances productivity by facilitating double-sided printing without manual intervention.
  • High-quality printing
    Achieve professional monochrome printing with a maximum resolution of 1200 x 1200 DPI. The Canon i-SENSYS LBP212dw ensures crisp, clear text and graphics for all your documents.
  • Versatile connectivity
    Offering both wired and wireless connectivity options, including Gigabit Ethernet, USB 2.0, and Wi-Fi, along with support for Apple AirPrint, Google Cloud Print, and Mopria Print Service, this printer provides the flexibility needed to support a variety of workplace setups and mobile printing needs.
Canon i-SENSYS LBP212dw - printer - B/W - laser
Printer Type
Workgroup printer - laser - B/W
9.5 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 33 ppm - B/W - A4 (210 x 297 mm) , Up to 52.5 ppm - B/W - A5 (148 x 210 mm) , Up to 26.4 ipm - B/W duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
1200 x 1200 dpi
Automatic Duplexing
USB 2.0, Gigabit LAN, Wi-Fi(n)
AirPrint Enabled
RAM Installed (Max)
1 GB
Language Simulation
PCL 5E, PCL 6, PDF, Canon Ultra Fast Rendering (UFRII), TIFF, JPEG
Media Type
Envelopes, labels, plain paper, recycled paper, thin paper, postcards
Total Media Capacity
350 sheets
Media Handling
100-sheet multipurpose tray, 250-sheet paper cassette
Monthly Duty Cycle (max)
80000 pages
Recommended Monthly Volume
750 - 4000 pages
Print server
Linux, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Android, Apple iOS, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Windows 8.1, Windows 10, Apple OS X 10.8.5 Mountain Lion or later, Microsoft Windows Server 2016
40.1 cm x 37.3 cm x 25 cm
Printer Type
Workgroup printer - laser - monochrome
Printer
Print Speed
Built-in Devices
Numeric key pad, LCD display
Wireless
AirPrint Enabled
1200 x 1200 dpi
Automatic Duplexing
First Print Out Time B/W
5.5 sec
Language Simulation
Fonts Included
45 x PCL
Media Handling
RAM
RAM Installed (Max)
1 GB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, 215.9 x 355.6 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
Media Weight
52 g/m² - 163 g/m²
350 sheets
Media Feeders
Paper cassette: 1 - 250 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 120 g/m² , Bypass tray: 1 - 100 sheets - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 52 g/m² - 163 g/m²
Output Trays Capacity
150 sheets
Duty Cycle
80000 pages
750 - 4000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1600 pages
Power supply
Frequency Required
50/60 Hz
1300 Watt
Power Consumption Stand by
10 Watt
Power Consumption Sleep
0.9 Watt
Software Included
Drivers & Utilities
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
56 dB
40.1 cm
37.3 cm
25 cm
9.5 kg
