The i-SENSYS LBP151dw is a fast, compact, PCL-ready, Wi-Fi and mobile-enabled black and white laser printer that's affordably priced and ideal for a wide range of uses.
Speed, space and savings
The i-SENSYS LBP151dw delivers outstanding speed from a space-saving device, at a very affordable price point. A brisk print speed of 27 ppm is complemented by double-sided printing, a first page out time (FPOT) of 8 seconds and Canon's Quick First-Print technologies, to ensure speedy printouts, even from sleep mode. -
Wi-Fi, network and mobile-ready
Connecting the printer to an Ethernet or Wi-Fi network is as easy as pushing a button. You can print wirelessly from any Mopria-enabled mobile device, using the free plugin. And you can access a wide range of advanced features on your iOS or Android device with the free-of-charge Canon PRINT Business app. -
Google cloud print-ready
The i-SENSYS LBP151dw will connect directly to the cloud without a PC. You can connect it to your Google Cloud Print account in seconds, and immediately start printing to it from any enabled device. -
PCL-ready
For IT professionals, the i-SENSYS LBP151dw is the perfect solution to numerous problems, attaching seamlessly to the network and providing compact, inexpensive reliability. -
Efficient, low power consumption
This printer is both quiet, making it ideal for retail environments, bank branches and hotel receptions and has class-leading energy efficient with low power consumption.
- Canon i-SENSYS LBP151dw - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 8.6 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 127 mm
- Max Media Size (Custom)
- 216 mm x 356 mm
- Print Speed
- Up to 27 ppm - B/W - A4 (210 x 297 mm) , Up to 15 ipm - B/W duplex - A4 (210 x 297 mm)
- Max Resolution (B&W)
- 1200 x 1200 dpi
- Automatic Duplexing
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- Processor
- 400 MHz
- RAM Installed (Max)
- 512 MB
- Language Simulation
- PCL 5E, PCL 6, Canon Ultra Fast Rendering (UFRII)
- Media Type
- Envelopes, transparencies, labels, plain paper, heavy-weight paper, recycled paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet paper cassette, 1-sheet multipurpose tray
- Monthly Duty Cycle (max)
- 15000 pages
- Recommended Monthly Volume
- 500 - 2000 pages
- Networking
- Print server
- System Requirements
- Linux, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Apple MacOS X 10.5.8 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows Vista / 7 / 8 / 8.1 / 10
- 39 cm x 36.5 cm x 24.5 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- 1200 x 1200 dpi
- First Print Out Time B/W
- 8 sec
- Fonts Included
- 45 x PCL
- Media Handling
- Processor
- 400 MHz
RAM
- 512 MB
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 127 mm
- 216 mm x 356 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Foolscap (216 x 343 mm)
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m² , 1 x automatic - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
Duty Cycle
- 15000 pages
- 500 - 2000 pages
- Networking
- Print server
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1700 pages - Canon 737 Starter
- ISO/IEC 19752, ISO 9296
- Power Device
- Power supply - internal
- Frequency Required
- 50/60 Hz
- 1120 Watt
- Power Consumption Stand by
- 2.6 Watt
- Power Consumption Sleep
- 1.1 Watt
- Software Included
- Drivers & Utilities, Canon Print Service plug-in for Android, Canon PRINT Business
- OS Required
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
- Sound Emission (Operating)
- 52 dB
- 39 cm
- 36.5 cm
- 24.5 cm
- 8.6 kg
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £3.68 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £9.87 |
