Canon i-SENSYS FAX-L380S - multifunction ( copier / fax / printer ) ( B/W )
Quicklinx: 5B8LWS00 Mfr#: 0815B020AC
This Super G3 laser fax transmits documents at 3 seconds per page so phone costs are reduced and less time is spent standing at the machine. Multiple faxes can be received without blocking the line saving even more time.
If paper or toner runs out at night or during the weekend, the 510-page memory safely stores all incoming documents for printing out later. Lengthy documents can also be scanned rapidly before transmission and are then sent automatically from memory.
The i-SENSYS FAX-380S features a Departmental ID Management function to control costs and enhance security. This allows you to set and store different IDs and passwords for each department and restrict fax use to authorized staff only. Ideal for management and accounting purposes, it allows you to check fax, print and copy totals regularly for each user and every department.
A 250-sheet paper capacity ensures that the cassette needs refilling far less often. With the 50-page Automatic Document Feeder lengthy documents can be faxed in a single operation without splitting them up first. Dialing is quick and simple as 31 one-touch and 100 coded dials store all your regular numbers. An optional telephone handset adds to convenience.
Benefit from laser quality faxing on plain paper with crisp, clear images. When transmitting detailed documents, such as diagrams or photos combined with text, Canon's unique Ultra High Quality technology ensures a perfect finish every time. The half-tone reproduction with 256 grAy scales gives extra depth and clarity.
The i-SENSYS FAX-380S can be used as an 18 pages per minute laser printer or copier, via the USB connection. Get superior quality output with a high 600 dpi resolution.
Simply replace the All-in-One cartridge containing toner and all essential parts and your fax is as good as new. There's no mess, no hassle - just continuous high quality output.
Canon i-SENSYS FAX-L380S - multifunction printer - B/W
Multifunction printer
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 18 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 18 ppm
Max Printing Resolution
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Original Size
148 mm width (min) - 210 mm width (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Type
Envelopes, plain paper
Standard Media Capacity
250 sheets
Connection Availability
USB
AC 230 V (50/60Hz)
43.8 cm x 58.5 cm x 34.8 cm
11 kg
Environmental Standards
ENERGY STAR Qualified
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 20 characters
USB
Copying
Max Copying Speed
Up to 18 ppm
Grayscale Half-Tones
256
Maximum Copies
99
Copying Features
Toner Save
Printing
Max Printing Speed
Up to 18 ppm
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Max Battery Backup Time
1 hour(s)
Reception Memory Capacity
Up to 510 pages
Transmission Memory Capacity
Up to 510 pages
Fax Printing Speed
Up to 18 ppm
Fax Printing Resolution
1200 x 600 dpi
Handset
Optional
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
31 station(s)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
141 stations
Delayed Transmission
141 stations
Remote Fax Retrieval (Polling)
Activity report, automatic redialing, smoothing, answering machine interface
Document & Media Handling
Min Original Size
148 mm width
Max Original Size
210 mm width
Original Type
Sheets
50 sheets
Supported Media Type
250 sheets
ADF - 50 sheets , Paper cassette - 250 sheets
Speed Details
Copying: up to 18 ppm , Printing: up to 18 ppm , Scanning: up to 25 ppm
1 x USB
Operating System Support
MS Windows XP, MS Windows 2000, MS Windows ME, MS Windows 98, MS Windows Vista
AC 230 V (50/60Hz)
530 Watt
Power Consumption Standby
9 Watt
Power Consumption Sleep
5 Watt
Consumables Included
1 x toner cartridge - up to 3500 pages
ENERGY STAR Certified
43.8 cm
58.5 cm
34.8 cm
11 kg
Sound Emission
30 dBA (idle) / 55 dBA (operating)
Resources
The following resources are available for the Canon i-SENSYS FAX-L380S - multifunction ( copier / fax / printer ) ( B/W )
