Canon i-SENSYS FAX-L170 Multifunction Printer
Quicklinx: CFBRWS00 Mfr#: 5258B028
This compact Super G3 fax is effortless to use and maintain. Offering superb energy efficiency with a range of professional fax features it's the ideal solution for small and medium-sized businesses.
  • Quick, efficient faxing
    This Super G3 fax can cut your communication costs down to a minimum. It transmits documents in as little as 3 seconds per page. With faxes sent and received in the shortest time possible, the telephone line is freed up.
  • Effortless faxing
    If paper or toner run out, a 512-page memory safely stores all incoming documents so you can print out faxes later. For easier operation, lengthy documents can be scanned into the memory and sent automatically - saving time and money.
  • Simple, fast dialing
    Even inexperienced users will find i-SENSYS FAX-L170 easy to operate. Dialing couldn't be simpler with 30 one-touch and 100 coded speed dials storing all your regular numbers. A clear, intuitive LCD display makes this fax particularly easy to use.
  • Easier workflow
    Users can fax or copy lengthy documents smoothly, in a single operation, rather than feeding them through a page at a time - thanks to the 30-page automatic document feeder. A 150-sheet capacity paper tray also saves time refilling paper.
  • Fast printing and copying
    Use this fax as a productive 18-pages-per-minute laser printer via the USB connection. With Quick First Print technology, there is a fast warm-up time from sleep mode. You can also copy documents at 11.8 pages per minute.
  • Minimum maintenance
    The i-SENSYS FAX-L170's all-in-one cartridge, which contains toner, drum and all essential parts, can be replaced in seconds. There's no mess or hassle, and by using an authentic Canon cartridge, you can be sure of continuous high quality output.
  • Leading energy efficiency
    This environmentally friendly fax has class-leading energy efficiency, consuming only 1.5 Watts in sleep mode.
  • Built-in handset
    i-SENSYS FAX-L170 has a handset for making and answering calls, with automatic fax/tel switching between faxes and voice calls.
Canon i-SENSYS FAX-L170 - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
Super G3 - plain paper
Printing Technology
Laser (monochrome)
Monthly Duty Cycle (max)
8000 impressions
Max Copying Speed
Up to 11.8 ppm
Max Copying Resolution
Up to 600 x 600 dpi
Max Printing Speed
Up to 18 ppm
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Original Size
127 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
30 sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
Standard Media Capacity
150 sheets
Output Trays Capacity
100 sheets
Connection Availability
USB 2.0
Office Machine Features
Ultra High Quality (UHQ) image processing
AC 230 V (50/60Hz)
37.2 cm x 30.3 cm x 30.3 cm
8.8 kg
Environmental Standards
ENERGY STAR Qualified
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
8000 impressions
Display
5 lines
USB 2.0
Standard Memory
64 MB 64 MB
Copying
Max Copying Speed
Up to 11.8 ppm
Up to 600 x 600 dpi
Grayscale Half-Tones
256
Max Document Enlargement
200%
Max Document Reduction
50%
Maximum Copies
99
Exposure Modes
Text, photo, text and photo
Copying Features
Toner Save
Printing
Max Printing Speed
Up to 18 ppm
Printer Drivers / Emulations
UFRII LT
Fax Machine
Compatibility
Super G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR
Fax Resolutions
200 x 400 dpi
Max Battery Backup Time
5 minutes
Total Memory Capacity
Up to 512 pages
Fax Printing Speed
Up to 18 ppm
Fax Printing Resolution
1200 x 600 dpi
Handset
Corded handset
Fax Machine Features
Error Correction Mode (ECM)
One-Touch Dialing
30 station(s)
Speed Dialing
100 station(s)
Telephone / Fax Switch
Broadcast Transmission
140 stations
Delayed Transmission
140 stations
Automatic redialing, remote reception, Dual Access, auto reduction
Document & Media Handling
Min Original Size
127 x 139.7 mm
Max Original Size
Original Type
Sheets
30 sheets
Min Media Size
76.2 x 127 mm
Max Media Size
Legal
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
150 sheets
100 sheets
Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 30 sheets size: 127 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 18 ppm - B/W , Copying: up to 11.8 ppm - B/W
1 x USB 2.0
Operating System Support
MS Windows XP, MS Windows 2000, Linux, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.4.9 - 10.7.x
Software Included
Drivers & Utilities
AC 230 V (50/60Hz)
1.02 kW
Power Consumption Standby
10 Watt
Power Consumption Sleep
1.5 Watt
Warm-Up Time
14 sec
First Copy Out Time B/W
22.3 sec
Consumables Included
1 x toner cartridge (black) - up to 1000 pages - Canon 728 Starter
ENERGY STAR Certified
37.2 cm
30.3 cm
30.3 cm
8.8 kg
Sound Emission
53 dB (operating)
10 °C
30 °C
20 - 80% (non-condensing)
CFBR Canon MF4410 BLACK TONER In Stock £58.46
