i-SENSYS FAX-L150 has a cost-effective all-in-one cartridge, which contains toner, drum and all essential parts. Simply replace the cartridge in seconds - there's no mess or hassle. Use an authentic Canon cartridge and you can be sure of continuous high quality output.
Fast, cost-effective faxing
Cut your communication costs down to a minimum with this super G3 fax, which transmits documents in as little as 3 seconds per page. As faxes can be sent and received in the shortest time possible, the telephone line is freed up. -
Greater efficiency
A 512-page memory safely stores all incoming documents so you can print out faxes later if paper or toner run out. Lengthy documents can also be scanned into the memory to be sent automatically, cutting transmission time and fax costs. -
Quick, simple operation
Dialing couldn't be simpler, even for inexperienced users, with all your regular numbers accessed by 15 one-touch and 100 coded speed dials. A clear, intuitive 5-line LCD display makes this fax particularly easy to use. -
More productive working
Thanks to the 30-page automatic document feeder, users can fax or copy lengthy documents smoothly, in a single operation, rather than feeding them through a page at a time. A 150-sheet capacity paper tray also saves time refilling paper. -
Fast printing and copying
Use this fax as a productive 18-page-per-minute laser printer via the USB connection. With Quick First Print technology there is a fast warm-up time from sleep mode. You can also copy documents at 11.8 pages per minute. -
Simple maintenance
i-SENSYS FAX-L150 has a cost-effective all-in-one cartridge, which contains toner, drum and all essential parts. Simply replace the cartridge in seconds - there's no mess or hassle. Use an authentic Canon cartridge and you can be sure of continuous high quality output. -
Exceptional energy efficiency
This environmentally friendly fax has class-leading energy efficiency, consuming only 1.5 watts in sleep mode.
- Canon i-SENSYS FAX-L150 - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 8000 impressions
- Max Copying Speed
- Up to 11.8 ppm
- Max Copying Resolution
- Up to 600 x 600 dpi
- Max Printing Speed
- Up to 18 ppm
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR
- Fax Resolutions
- 200 x 400 dpi
- Original Size
- 127 x 139.7 mm (min) - A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 30 sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper, heavy-weight paper
- Standard Media Capacity
- 150 sheets
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0
- Office Machine Features
- Ultra High Quality (UHQ) image processing
- Power
- AC 230 V (50/60Hz)
- 37.2 cm x 30.3 cm x 30.3 cm
- 8.6 kg
- Environmental Standards
- ENERGY STAR Qualified
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 8000 impressions
- Display
- 5 lines
- Interface
- USB 2.0
- Standard Memory
- 64 MB 64 MB
Copying
- Max Copying Speed
- Up to 11.8 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 200%
- Max Document Reduction
- 50%
- Maximum Copies
- 99
- Exposure Modes
- Text, photo, text and photo
- Copying Features
- Toner Save
Printing
- Up to 18 ppm
- Printer Drivers / Emulations
- UFRII LT
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR
- Fax Resolutions
- 200 x 400 dpi
- Max Battery Backup Time
- 5 minutes
- Total Memory Capacity
- Up to 512 pages
- Fax Printing Speed
- Up to 18 ppm
- Fax Printing Resolution
- 1200 x 600 dpi
- Handset
- Optional
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 15 station(s)
- Speed Dialing
- 100 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 125 stations
- Delayed Transmission
- 125 stations
- Automatic redialing, remote reception, Dual Access, auto reduction
Document & Media Handling
- Min Original Size
- 127 x 139.7 mm
- Max Original Size
- Original Type
- Sheets
- 30 sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- Legal
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), 76.2 x 127 mm
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 150 sheets
- 100 sheets
- Paper cassette - 150 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) , ADF - 30 sheets size: 127 x 139.7 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm)
- Speed Details
- Printing: up to 18 ppm - B/W , Copying: up to 11.8 ppm - B/W
- 1 x USB 2.0
- Operating System Support
- MS Windows XP, MS Windows 2000, Linux, MS Windows 7, MS Windows Vista, Apple Mac OS X 10.4.9 - 10.7.x
- Software Included
- Drivers & Utilities
- Voltage Required
- 1.02 kW
- Power Consumption Standby
- 10 Watt
- Power Consumption Sleep
- 1.5 Watt
- Warm-Up Time
- 14 sec
- First Copy Out Time B/W
- 22.3 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages - Canon 728 Starter
- ENERGY STAR Certified
- 37.2 cm
- 30.3 cm
- 30.3 cm
- 8.6 kg
- Sound Emission
- 53 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% (non-condensing)
Canon MF4410 BLACK TONER | In Stock | £57.19 |
