The EOS M50 Mark II carries and builds on the strong performance of the popular EOS M50 with improvements that will be especially notable for content creators like vloggers and more. You still get the impressive image quality of the 24.1MP CMOS sensor, power of the DIGIC 8 image processor, 4K UHD 24p and HD 120p for slow motion video and more, along with some additional boosts. The autofocus locks onto the subject faster, and Eye Detection is improved so it recognizes the eye and face further away. Eye Detection can now even be used during video with Movie Servo AF, and you can use both Eye and Face Detection during Servo AF. What you get is added versatility and stability to keep the subject(s) in focus and as the center of attention. For content creators, you can use the EOS M50 Mark II to livestream your content with built-in Wi-Fi, and use with EOS Webcam Utility software for an easy webcam alternative. When a different angle is needed, you can shoot vertically in addition to horizontally, and the camera even offers clean HDMI output for high-resolution, high frame-rate streaming. When it comes to content, whether stills or video, the EOS M50 Mark II goes far beyond letting you just scratch the surface of your vision.
24.1 Megapixel (APS-C) CMOS sensor
The EOS M50 Mark II features a powerful 24.1 Megapixel CMOS (APS-C) sensor that can capture high-resolution images and 4K videos. The large CMOS sensor utilizes a sophisticated light-capturing design, helping to shoot images and videos with reduced noise, delivering clear, detailed results even in low light. It also enables fast continuous shooting and fast autofocus for high-speed performance that helps you capture once-in-a-lifetime moments. -
DIGIC 8 Image Processor with Auto Lighting Optimizer
Helping to improve autofocus performance, the EOS M50 Mark II features the DIGIC 8 Image Processor, which also ensures that your photos and videos look sharp and detailed with minimal noise or grain, in virtually any lighting. Combined with the Auto Lighting Optimizer, it also helps analyze the image and helps minimize blown-out areas by maintaining color and detail in bright parts of a photo. When set to High, it can even smooth the transitions between colors, assisting you to take impressively lifelike images. -
Vari-angle touchscreen LCD convenient for vlogging and various compositions
The EOS M50 Mark II camera features a 3.0-inch, 1.04 Megapixel clear view LCD II vari-angle touchscreen LCD. Brightness is adjustable and its extensive flexibility makes it easy to compose and shoot from virtually any angle, making selfies simple and enabling the LCD to fold away when not in use. Touchscreen features include quickly changing settings, reviewing stills and videos, and even AF point selection. -
Movie self-timer with touch record control
This feature allows you to select how many seconds (between 2 to 10 seconds) you will need before your video starts to record so you ensure you get the scene and subjects needed in the shot, for the shot. -
Clean HDMI output
Whether you're creating inspiring video clips or capturing special occasions, the advanced video capabilities of the EOS M50 Mark II camera can catch them in the quality they deserve. Video is smooth and richly detailed even when played back on a large-screen HDTV via the camera's HDMI output. It is even possible to choose movie output without any information displayed on your screen. -
Built-in 2.36 million dots OLED EVF
The EOS M50 Mark II camera features a high-precision 0.39-inch OLED (Organic Light-Emitting Diode) EVF with approx. 2.36 million dots. The electronic viewfinder (EVF) provides a bright, sharp and colorful 100% view of the subject at hand. Equipped with an aspherical lens, the EVF shows a crisp and vivid image with minimal distortion, even when the eye moves off the center of the visual field. -
Built-in Wi-Fi technology
The EOS M50 Mark II camera is designed to make connecting to a Wi-Fi network fast and easy. It can exchange data with other Wi-Fi connected compatible Canon cameras, and transfer files directly to a compatible smart device using the Camera Connect app. -
Built-in Bluetooth capability
Bluetooth pairing helps you connect the camera to compatible smart devices using the Canon Camera Connect app. To customize the Bluetooth function, simply click on the network icon located on the LCD screen.
- Canon EOS M50 Mark II - digital camera EF-M 15-45mm IS STM lens
- Product Type
- Digital camera - 4K - mirrorless system
- Lens Included
- EF-M 15-45mm IS STM lens
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 8
- Wireless Interface
- Wi-Fi, Bluetooth
- Sensor Resolution
- 24.1 Megapixel
- Max Video Resolution
- 3840 x 2160
- Lens System
- Zoom lens - 3x zoom - 15 - 45 mm - f/3.5-6.3 STM Canon EF-M
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 25 cm
- Image Stabiliser
- Optical
- Camera Flash
- Pop-up flash
- Viewfinder
- Electronic - 0.39" - colour - OLED
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E12 Li-ion rechargeable battery (included)
- Interface
- HDMI, USB 2.0
- White with silver lens
- 11.63 cm x 5.87 cm x 8.81 cm
- 350 g
- 2-year warranty
- Product Type
- Lens Included
- Enclosure Colour
- Sensor Resolution
- 24.1 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 25,800,000 pixels
- Effective Sensor Resolution
- 24,100,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- Frame Rate (Max Resolution)
- 24 fps
- ISO (Max)
- 51200
- Extended ISO (Max)
- 51200
- Sensor Dust Reduction
- Sensor Features
- EOS Integrated Cleaning System
- Optical Zoom
- 3x
- Image Processor
- DIGIC 8
- Image Stabiliser
- Optical
- Face Detection
- Print Standard
- Direct print, Exif Print support, PictBridge support
- Auto Focus
- Dual Pixel CMOS AF
- Auto Focus Points (Zones) Qty
- 143
- AE/AF Control
- Face-priority AF, Subject-tracking AF, Eye detection AF, Zone AF, Touch and Drag AF
- Face Detection
- Eye Detect AF, face-priority AF function
- Digital Video Format
- H.264
- Image Recording Format
- JPEG, RAW, RAW + JPEG, C-RAW
- 3840 x 2160
- Audio Signal Format
- AAC
- Interface
- HDMI, USB 2.0, IEEE 802.11b/g/n, Bluetooth 4.2
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view, Wireless Image Transfer, Live streaming
Exposure & White Balance
- Light Sensitivity
- ISO auto, ISO 51200, ISO 100-25600
- Exposure Metering
- Evaluative, centre-weighted, spot
- Exposure Metering Zones
- 384
- Exposure Modes
- Automatic, manual, aperture-priority, shutter-priority
- Special Effects
- Soft, Cool, Warm, Black & White, Neutral, Vivid, purple, blue, green, Faithful, monochrome, landscape, portrait, Standard, Fine Detail, Shine, Lime, Peach
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (white)
- Shutter Type
- Electronic, mechanical electronically-controlled
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±3 EV range, in 1/3 EV steps
- X-sync Speed
- 1/200sec
- Exposure Range
- EV -2-20 (ISO 100)
Lens System
- Focal Length Equivalent to 35mm Camera
- 24 - 72mm
- Focus Adjustment
- Automatic, manual
- 25 cm
- Max View Angle
- 84.3 degree(s)
- Zoom Adjustment
- Manual
- Lens Construction
- 9 groups / 10 elements
- Filter Size
- 49 mm
- Lens Mounting Type
- Canon EF-M
- Full-time manual focusing, Stepping Motor (STM) technology
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 5
- Flash Modes
- Rear curtain sync, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
- Continuous Shooting Speed
- 10 frames per second, 7.4 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- RGB primary colour filter, depth-of-field preview button, AE lock, AF lock, cropping an image, resizing an image, saturation control, highlight tone priority, brightness control, contrast control, Auto Lighting Optimizer, peripheral illumination correction, Time-Lapse recording, noise reduction over long exposures, high ISO speed noise reduction, silent shooting, GPS via mobile, Hybrid Auto, distortion correction function, PC webcam option, tilt adjustment, diffraction correction, slow motion recording, chromatic aberration correction, vertical video support, movie self-timer, Digital Lens Optimizer (DLO)
Viewfinder
- Viewfinder Type
- Electronic - OLED
- Viewfinder Colour Support
- Viewfinder Diagonal Size
- 0.39"
- Viewfinder Resolution
- 2,360,000 pixels
Display
- 3" LCD display
- Display Format
- 1,040,000 pixels
- Display Form Factor
- Rotating
- Touch Screen
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Microphone Features
- Wind noise reduction, sensitivity control
- Connector Type
- USB 2.0 (5 pin Micro-USB Type B) , HDMI output (19 pin micro HDMI Type D)
- Included Accessories
- Battery charger, dust cap, body cap, lens cap, neck strap, hot shoe cover
- Battery Type
- Canon LP-E12 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 275 shots (at 23 °C (EVF on)) , Photo shooting - 245 shots (at 0 °C (EVF on)) , Photo shooting - 320 shots (at 23 °C (LCD Monitor on)) , Photo shooting - 305 shots (at 0 °C (LCD Monitor on))
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card Included
- No
- Image Storage
- RAW 6000 x 4000 , JPEG 6000 x 4000 , JPEG 3984 x 2656 , JPEG 2976 x 1984 , JPEG 2400 x 1600 , JPEG 6000 x 3368 , JPEG 3984 x 2240 , JPEG 2976 x 1680 , JPEG 2400 x 1344 , JPEG 5328 x 4000 , JPEG 3552 x 2664 , JPEG 2656 x 1992 , JPEG 2112 x 1600 , JPEG 4000 x 4000 , JPEG 2656 x 2656 , JPEG 1984 x 1984 , JPEG 1600 x 1600
- Video Capture
- H.264 - 3840 x 2160 p - 23.98 fps , H.264 - 1920 x 1080 p - 59.94 fps , H.264 - 1920 x 1080 p - 29.97 fps , H.264 - 1920 x 1080 p - 23.98 fps , H.264 - 1280 x 720 p - 59.94 fps , H.264 - 1280 x 720 p - 119.9 fps
- Limited warranty - 2 years
- 11.63 cm
- 5.87 cm
- 8.81 cm
- 350 g
- Weight Details
- Camera body only: 350 g , Camera with battery and memory card: 387 g
- 0 °C
- 40 °C
- 0 - 85%
