Let your creativity grow
Step into DSLR photography and let your creativity grow. Produce superb photos and video with an 18-megapixel sensor and enjoy shooting with an easy to use Vari-angle Clear View LCD II Touch screen.
Create high-quality low-noise images that are packed with detail
Shoot 18-megapixel photos and Full-HD video from the same camera
Movie Servo AF keeps moving subjects in focus when shooting video
Explore different shooting angles with a Vari-Angle Clear View LCD II Touch Screen
Get shooting quickly and easily with Scene Intelligent Auto
Superb image quality
Capture every detail with an 18-megapixel Hybrid CMOS AF sensor. The EOS 700D produces low-noise images that can be printed at large sizes or cropped for alternative compositions.
Produce Full HD movie projects
Shoot video at 1080p resolution, enjoying the right level of automatic or manual control for you. Hybrid AF technology enables continuous focusing when shooting video, and the EOS 700D supports near-silent Movie Servo AF with compatible STM lenses. Record stereo sound with a built-in or external microphone.
Keep up with fast moving action
Track moving subjects even if they move across the scene with an autofocus system comprising 9 cross-type AF points. Continuous shooting at 5 fps for bursts of up to 22 shots means you'll never miss that decisive moment.
Explore new angles
Compose photos and movies from new and interesting angles using the EOS 700D's Vari-angle 7.7cm (3.0") 3:2 ratio Clear View LCD II Touch screen. Shoot over the top of crowds, or go for a dramatic ground-level viewpoint.
Touch-screen control
The EOS 700D is easy to use from the moment you first pick it up. Shoot and focus with a single tap of the camera's touch screen, and use pinch and swipe gestures to navigate when reviewing images.
Shoot great pictures easily. Canon's Scene Intelligent Auto mode analyses the scene and selects the most appropriate cameras settings automatically.
Low-light performance
Take great pictures even in low light, shooting without flash to capture the true ambience of an occasion. The EOS 700D features an ISO sensitivity range of ISO 100-12800 (extendable to ISO 25600).
Great results in difficult conditions
HDR Backlight Control mode captures three different exposures and combines them into one, retaining shadow and highlight detail. The EOS 700D's Hand Held Night Scene mode captures multiple images at fast shutter speeds and blends them together for a blur-free result.
Explore with the EOS System
Take your photography further with an extensive range of lenses, accessories and flashes that make up the EOS System.
Capture every detail with an 18-megapixel Hybrid CMOS AF sensor. The EOS 700D produces low-noise images that can be printed at large sizes or cropped for alternative compositions. -
Shoot video at 1080p resolution, enjoying the right level of automatic or manual control for you. Hybrid AF technology enables continuous focusing when shooting video, and the EOS 700D supports near-silent Movie Servo AF with compatible STM lenses. Record stereo sound with a built-in or external microphone. -
Track moving subjects even if they move across the scene with an autofocus system comprising 9 cross-type AF points. Continuous shooting at 5 fps for bursts of up to 22 shots means you'll never miss that decisive moment. -
Explore new angles
Compose photos and movies from the interesting angles using the EOS 700D's Vari-angle 7.7cm (3.0") 3:2 ratio Clear View LCD II touch screen. Shoot over the top of crowds, or go for a dramatic ground-level viewpoint. -
The EOS 700D is easy to use from the moment you first pick it up. Shoot and focus with a single tap of the camera's touch screen, and use pinch and swipe gestures to navigate when reviewing images. -
Scene intelligent auto
Shoot great pictures easily. Canon's scene intelligent auto mode analyzes the scene and selects the most appropriate cameras settings automatically. -
Take complete control
When you're ready to advance your photography choose to aperture priority, shutter priority or manual mode for complete control over your images. -
Take great pictures even in low light, shooting without flash to capture the true ambience of an occasion. The EOS 700D features an ISO sensitivity range of ISO 100-12800 (extendable to ISO 25600). -
HDR backlight control mode captures three different exposures and combines them into one, retaining shadow and highlight detail. The EOS 700D's Hand Held Night Scene mode captures multiple images at fast shutter speeds and blends them together for a blur-free result.
- Canon EOS 700D - digital camera - body only
- Product Type
- Digital camera - 1080p - SLR with Live View mode, movie recording
- Lens Included
- Body only
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 5
- Sensor Resolution
- 18.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Camera Flash
- Pop-up flash
- Viewfinder
- Optical - fixed eye-level pentamirror
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E8 Li-ion rechargeable battery - 1120 mAh (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Microsoft Certification
- Compatible with Windows 7
- 13.31 cm x 7.88 cm x 9.98 cm
- 580 g
- Product Type
- Lens Included
- Body only
- Sensor Resolution
- 18.0 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 18,500,000 pixels
- Effective Sensor Resolution
- 18,000,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- ISO (Max)
- 25600
- Sensor Dust Reduction
- Sensor Features
- EOS Integrated Cleaning System, Self Cleaning Sensor Unit
- Image Processor
- DIGIC 5
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- Hybrid
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- FlexiZone, Face-priority AF, Subject-tracking AF, Movie Servo AF
- Face Detection
- Automatic Face Tracking technology, Live Face detection AF mode
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Auto Focus Features
- Predictive Focus Control
- Interface
Exposure & White Balance
- Light Sensitivity
- ISO 25600, ISO 100-12800, ISO auto (100-6400)
- Exposure Metering
- Evaluative, centre-weighted, spot, partial
- Exposure Metering Zones
- 63
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, close-up, night portrait, sports mode, handheld night shot, backlight correction HDR
- Special Effects
- Neutral, Faithful, monochrome, landscape, portrait
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (white)
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±5 EV range, in 1/2 or 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/2 or 1/3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/200sec
- Exposure Range
- EV 1-20 (ISO 100)
Lens System
- Lens Mounting Type
- Canon EF/EF-S
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 13
- Flash Modes
- Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation, wireless off-camera control
Additional Features
- Continuous Shooting Speed
- 5 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- Built-in speaker, RGB primary colour filter, auto power save, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, resizing an image, GPS ready, highlight point display, Dust Delete Data system, face detection, built-in help guide, HDR image enhancement technology, Eye-Fi Card Ready, Picture Style Auto, Scene Intelligent Auto technology, Image Rating
Viewfinder
- Viewfinder Type
- Optical Viewfinder Field Coverage
- 95%
- Optical Viewfinder Magnification
- 0.85x
- Optical Viewfinder Dioptric Correction Range
- -3 to +1
- Viewfinder Frames
- Autofocus frame
Display
- 3" LCD display
- Display Format
- 1,040,000 pixels
- Display Form Factor
- Rotating
- Touch Screen
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output , Microphone
Software
- Software
- Canon PhotoStitch, Canon Digital Photo Professional, Canon Picture Style Editor, Canon ImageBrowser EX, Canon EOS Utility
- Included Accessories
- Eyepiece cover, battery charger, body cap, neck strap, USB cable, eyecup, battery cover
- Body Material
- Stainless steel, fibreglass-reinforced polycarbonate resin
- Battery Type
- Canon LP-E8 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 440 shots (at 23 °C (AE 50%, FE 50%)) , Photo shooting - 400 shots (at 0 °C (AE 50%, FE 50%))
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Image Storage
- RAW 5184 x 3456 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 1920 x 1280 , JPEG 720 x 480 , JPEG 4608 x 3456 , JPEG 3072 x 2304 , JPEG 2304 x 1728 , JPEG 1696 x 1280 , JPEG 5184 x 2912 , JPEG 3456 x 1944 , JPEG 2592 x 1456 , JPEG 1920 x 1080 , JPEG 720 x 400 , JPEG 3456 x 3456 , JPEG 2304 x 2304 , JPEG 3456 x 3456 , JPEG 2304 x 2304 , JPEG 1728 x 1728 , JPEG 1280 x 1280 , JPEG 480 x 480
- Video Capture
- H.264 - 1920 x 1080 - 30 fps , H.264 - 1920 x 1080 - 25 fps , H.264 - 1920 x 1080 - 24 fps , H.264 - 1280 x 720 - 60 fps , H.264 - 1280 x 720 - 50 fps , H.264 - 640 x 480 - 30 fps , H.264 - 640 x 480 - 25 fps
- 13.31 cm
- 7.88 cm
- 9.98 cm
- 580 g
- 0 °C
- 40 °C
- 0 - 85%
