Canon EOS 5D Mark II - Digital camera - SLR - 21.1 Mpix - body only
Canon EOS 5D Mark II Digital SLR
Quicklinx: 58LSWS00 Mfr#: 2764B015AA
Canon's update to the wildly popular full frame EOS 5D is here, and it's better than ever. The EOS 5D Mark II has a stunning 21.1-megapixel full-frame CMOS sensor with DIGIC 4 image processor, a vast ISO range of 100-6400, plus EOS technologies like auto lighting optimizer and peripheral illumination correction. It supports Live View shooting, Live View HD videos, and more. It can shoot up to 3.9 fps, has 9 AF points plus 6 AF assist points, a 98% coverage viewfinder, a 3.0-inch Clear View LCD and a rugged build.
  • Rugged design
    Built to withstand the elements, the Canon EOS 5D Mark II has a magnesium alloy body that's both dust-resistant and waterproof, ensuring durability in challenging conditions.
  • Exceptional image quality
    With a 21.1 megapixel Full Frame CMOS sensor, the Canon EOS 5D Mark II captures high-resolution images with superb detail and clarity, whether you're shooting landscapes or portraits.
  • Versatile shooting modes
    From automatic to manual, and special effects like Monochrome and Landscape, the Canon EOS 5D Mark II offers a variety of exposure modes and shooting programs to unleash your creativity.
  • Advanced video capabilities
    Record Full HD 1080p videos at 30 fps with the Canon EOS 5D Mark II. Its H.264 digital video format ensures high-quality recording, perfect for capturing those unforgettable moments.
  • Comprehensive connectivity
    Wi-Fi ready and equipped with HDMI, USB 2.0, and composite video/audio interfaces, the Canon EOS 5D Mark II offers versatile options for sharing and transferring your photos and videos.
Canon EOS 5D Mark II - digital camera - body only
Digital camera - 1080p - SLR with Live View mode, movie recording
Lens Included
Body only
Memory Card Slot
CompactFlash Card
Image Processor
DIGIC 4
Sensor Resolution
21.1 Megapixel
Viewfinder
Optical - fixed eye-level pentaprism
Display
LCD display - 3"
Supported Battery
Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
15.2 cm x 7.5 cm x 11.4 cm
0.81 kg
Lens Included
Body only
Sensor Resolution
21.1 Megapixel
Optical Sensor Type
CMOS
Total Pixels
22,000,000 pixels
Effective Sensor Resolution
21,100,000 pixels
Optical Sensor Size
Full Frame (36 x 24 mm)
Field of View Crop Factor
1.0
ISO (Max)
25600
Sensor Dust Reduction
Sensor Features
EOS Integrated Cleaning System
Image Processor
DIGIC 4
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
15
Digital Video Format
H.264
Image Recording Format
JPEG, RAW, RAW + JPEG
Connectivity Features
Wi-Fi ready
Exposure & White Balance
Light Sensitivity
ISO 50, ISO auto (100-3200), ISO 12800, ISO 25600, ISO 100-6400
Exposure Metering
Evaluative, spot AF area, centre-weighted, partial (8%), spot (3.5%)
Exposure Metering Zones
35
Exposure Modes
Programme, bulb, automatic, manual, aperture-priority, shutter-priority, E-TTL II program flash
Shooting Programs
Landscape, portrait mode
Special Effects
Neutral, Faithful, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/8000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±3 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 (ISO 100)
Lens System
Lens Mounting Type
Canon EF
Additional Features
Continuous Shooting Speed
3.9 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe, PC terminal
Additional Features
Audio recording, RGB primary colour filter, auto power save, digital noise reduction, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, LCD live view mode, highlight point display, takes photos while film recording, peripheral illumination correction
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
98%
Optical Viewfinder Magnification
0.71x
Optical Viewfinder Dioptric Correction Range
-3 to +1
Viewfinder Frames
Autofocus frame
Viewfinder Information
Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, aperture, white balance, metering system, battery status, high-speed sync indicator, flash compensation on/off, ISO sensitivity, memory card status, FE lock
Display
3" LCD display
Display Format
920,000 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB , Composite video/audio output , HDMI output , Remote control , Microphone
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture, Canon Digital Photo Professional, Canon wireless Remote Capture
Eyepiece cover, battery charger, body cap, neck strap, USB cable, eyecup, audio / video cable
Body Material
Magnesium alloy
Protection
Waterproof, dust-resistant
Battery Type
Canon LP-E6 Lithium Ion
Details
Memory / Storage
Memory Card Slot
CompactFlash Card
Supported Memory Cards
CompactFlash, Microdrive
Image Storage
Fine JPEG 5616 x 3744 - 6.1 MB , Normal JPEG 5616 x 3744 - 3 MB , Fine JPEG 4080 x 2720 - 3.6 MB , Normal JPEG 4080 x 2720 - 1.9 MB , Fine JPEG 2784 x 1856 - 2.1 MB , Normal JPEG 2784 x 1856 - 1 MB , RAW 5616 x 3744 - 25.8 MB
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 640 x 480 - 30 fps
15.2 cm
7.5 cm
11.4 cm
0.81 kg
58LS Canon RS 80N3 - Remote control - cable In Stock £42.59
Resources
The following resources are available for the Canon EOS 5D Mark II - Digital camera - SLR - 21.1 Mpix - body only
