Please Note: EOS 200D with 18-55mm lens shown for illustration purposes. 18-135mm lens supplied.
Affordable, easy to use, and delivers great results. This EOS 200D kit also includes an EF-S 18-135mm f/3.5-5.6 IS STM lens that's ideal for travel, landscapes and everyday photography
The world's lightest DSLR¹ with a Vari-angle screen - the EOS 200D is a great choice for landscapes, portraits and travel and captures great quality photos and movies with a next-generation 24.2-megapixel sensor. It's connected too, designed to work with smartphones and tablet computers². The included EF-S 18-135mm f/3.5-5.6 IS STM lens provides smooth quiet auto focusing for movies, and Dynamic Image Stabilizer reduces vibrations in video footage.
Benefits
- An ultra-compact DSLR that's easy to use and delivers superb results
- A great camera for landscapes, portraits and travel. Capture intricate detail with a 24.2-megapixel sensor
- The included EF-S 18-135mm f/3.5-5.6 IS STM lens is suitable for many different types of photography, from landscape to portrait
- Images are sharp and clear, thanks to autofocus that's accurate even in dim light
- STM focusing is fast when shooting photos and smoother for video
- Enjoy a responsive performance, whether you're composing with Live View or using the high-quality optical viewfinder³
- Low Energy Bluetooth® maintains a connection with your smart device without excessive battery drain
- Share images from your smart device and control your camera remotely, using Bluetooth® and Wi-Fi²
- Shoot superb Full HD video that looks amazing online and on your home TV
- Part of the EOS family: a system of lenses and accessories that empowers you to be creative
What's in the box
- EOS 200D Black
- EF-S 18-135mm f/3.5-5.6 IS STM lens Black
- Eyecup EF
- Camera Cover R-F-3
- Wide Strap EW-400D
- Battery Charger LP-E17 (with battery cover)
- Battery Pack LP-E17E Power Cable
Design that makes sense
With instinctive controls and a touchscreen that feels just like your smartphone, the EOS 200D is easy to use from the start. Shoot with a bright optical viewfinder to view the world as it really is, or a Vari-Angle screen that rotates to help you shoot from unusual perspectives. -
Photos you will love for years to come
Shoot 24.2-megapixel photos that are rich with detail and color and look fantastic straight from the camera - perfect for big prints, photobooks and on-line galleries and great for telling stories with your photos. The EOS 200D has a built-in DIGIC 7 processor so it can capture pictures in low-light conditions, and Dual Pixel CMOS AF for the world's fastest Live View focusing. -
Shoot shallow focus
The EOS 200D's large APS-C sensor makes it easy to shoot with shallow depth of field - ideal for portraits. Keep faces pin-sharp against a beautifully blurry background. It's an approach used by professional photographers the world over. -
More portable, more photos
The EOS 200D is a light DSLR with a Vari-Angle screen, designed to be carried without weighing you down so you can enjoy DSLR photography in more places. Take it on holiday, to parties and celebrations, or just out for a walk when you're feeling creative. -
How will you shoot?
However you like to use a camera, the EOS 200D delivers the same fast focusing and speedy responsive performance. Shoot using a lag-free optical viewfinder that shows the world as it really is, or compose using a smartphone-like Vari-Angle display and enjoy the world's fastest Live View AF. -
Movies made easy too
Great-quality Full HD movies are easy to shoot, with Dual Pixel CMOS AF for continuous focusing. -
A lesson in great photography
The EOS 200D's guided user interface helps you to choose the right settings for the effect you want to create. It's like having your own personal photography tutor standing right next to you.
- Canon EOS 200D - digital camera EF-S 18-135mm IS STM lens
- Product Type
- Digital camera - 1080p - SLR with Live View mode, movie recording
- Lens Included
- EF-S 18-135mm IS STM lens
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 7
- Wireless Interface
- Wi-Fi, Bluetooth, NFC
- Sensor Resolution
- 24.2 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 7.5x zoom - 18 - 135 mm - f/3.5-5.6 IS STM Canon EF-S
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 39 cm
- Image Stabiliser
- Optical (Dynamic Image Stabilizer)
- Camera Flash
- Pop-up flash
- Viewfinder
- Optical - fixed eye-level pentamirror
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E17 Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 12.24 cm x 6.98 cm x 9.26 cm
- 453 g
- Product Type
- Lens Included
- Enclosure Colour
- Black
- Sensor Resolution
- 24.2 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 25,800,000 pixels
- Effective Sensor Resolution
- 24,200,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- Frame Rate (Max Resolution)
- 60 fps
- ISO (Max)
- 51200
- Sensor Dust Reduction
- Sensor Features
- EOS Integrated Cleaning System, Self Cleaning Sensor Unit
- Optical Zoom
- 7.5x
- Image Processor
- DIGIC 7
- Image Stabiliser
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- Dual Pixel CMOS AF / TTL phase detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Predictive AI Servo AF, AI Focus AF
- Face Detection
- Automatic Face Tracking technology
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Auto Focus Features
- Predictive Focus Control
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, Bluetooth 4.0, NFC (Near Field Communication)
- Computer Connectivity
- Mac, Windows
Exposure & White Balance
- Light Sensitivity
- ISO 51200, ISO 100-25600, ISO auto (100-25600)
- Exposure Metering
- Evaluative, centre-weighted, partial (6%), spot (2.6%)
- Exposure Metering Zones
- 63
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority, E-TTL II program flash
- Shooting Programs
- Landscape, portrait mode, close-up, night portrait, food, sports mode, candle, kids, backlight correction HDR, handheld night scene, group photo
- Special Effects
- Neutral, fisheye, soft focus, Faithful, monochrome, landscape, portrait, miniature, Toy camera, HDR Art, Grainy B&W, Water painting, Fine Detail
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Cloudy, tungsten light, Flash, daylight, shade, fluorescent light (white)
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±5 EV range, in 1/2 or 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/2 or 1/3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/200sec
- Exposure Range
- EV 1-20 (ISO 100)
Lens System
- Focal Length Equivalent to 35mm Camera
- 29 - 216mm
- Focus Adjustment
- Automatic, manual
- 39 cm
- Max View Angle
- 74.3 degree(s)
- Zoom Adjustment
- Manual
- Lens Construction
- 12 groups / 16 elements
- Filter Size
- 67 mm
- Lens Mounting Type
- Canon EF/EF-S
- UD glass, internal focusing system, full-time manual focusing, aspherical lens, zoom lock switch, Stepping Motor (STM) technology
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 9.8
- Flash Modes
- Fill-in mode, rear curtain sync, auto mode, red-eye reduction
- Red-Eye Reduction
- Flash +/- compensation
Additional Features
- Continuous Shooting Speed
- 5 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- Audio recording, RGB primary colour filter, auto power save, depth-of-field preview button, camera orientation detection, histogram display, AE lock, AF lock, FE lock, highlight point display, Dust Delete Data system, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Multi-Frame Noise Reduction, HDR image enhancement technology, noise reduction over long exposures, high ISO speed noise reduction, distortion correction function, diffraction correction, chromatic aberration correction
Viewfinder
- Viewfinder Type
- Optical Viewfinder Field Coverage
- 95%
- Optical Viewfinder Magnification
- 0.87x
- Optical Viewfinder Dioptric Correction Range
- -3 to +1
- Viewfinder Information
- Shutter speed, exposure compensation, AE lock, flash charge completion, red-eye reduction, aperture, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock, AF status, AF point, grid, flicker detection, area AF frame, aspect ratio line, warning symbol
Display
- 3" LCD display
- Display Format
- 1,040,000 pixels
- Display Form Factor
- Rotating
- Touch Screen
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- USB / AV output , HDMI output (19 pin mini HDMI Type C) , Microphone (mini-phone stereo 3.5 mm)
Software
- Software
- Drivers & Utilities, Canon Digital Photo Professional 4
- Included Accessories
- Eyepiece cover, battery charger, dust cap, body cap, lens cap, neck strap, eyecup
- Body Material
- Aluminium alloy, fibreglass-reinforced polycarbonate resin
- Battery Type
- Canon LP-E17 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 650 shots (at 23 °C (LCD Monitor off)) , Photo shooting - 620 shots (at 0 °C (LCD Monitor off)) , Photo shooting - 260 shots (at 23 °C (Live View mode)) , Photo shooting - 240 shots (at 0 °C (Live View mode))
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card, SDHC UHS-I Memory Card, SDXC UHS-I Memory Card
- Memory Card Included
- No
- Image Storage
- RAW 6000 x 4000 , JPEG 6000 x 4000 , JPEG 3984 x 2656 , JPEG 2976 x 1984 , JPEG 2400 x 1600 , JPEG 5328 x 4000 , JPEG 3552 x 2664 , JPEG 2656 x 1992 , JPEG 2112 x 1600 , JPEG 6000 x 3368 , JPEG 3984 x 2240 , JPEG 2976 x 1680 , JPEG 2400 x 1344 , JPEG 4000 x 4000 , JPEG 2656 x 2656 , JPEG 1984 x 1984 , JPEG 1600 x 1600
- Video Capture
- H.264 - 1920 x 1080 p - 60 fps , H.264 - 1920 x 1080 p - 50 fps , H.264 - 1920 x 1080 p - 30 fps , H.264 - 1920 x 1080 p - 25 fps , H.264 - 1920 x 1080 p - 24 fps , H.264 - 1280 x 720 p - 60 fps , H.264 - 1280 x 720 p - 50 fps , H.264 - 1280 x 720 p - 30 fps , H.264 - 1280 x 720 p - 25 fps , H.264 - 640 x 480 p - 30 fps , H.264 - 640 x 480 p - 25 fps
- 12.24 cm
- 6.98 cm
- 9.26 cm
- 453 g
- Weight Details
- Camera with battery and memory card: 453 g
- 0 °C
- 40 °C
- 0 - 85%
