Capture superb detailed images thanks to a large 18.0 Megapixel APS-C size sensor. Print your images up to A2 size or creatively crop them and still achieve great quality. Take memorable, atmospheric pictures in low light with a large ISO sensitivity range of ISO 100-6400 (expandable to ISO 12,800), which reduces the need for flash - so you can capture the natural ambience of every precious moment.
Shoot and share unique DSLR quality
Effortlessly capture distinctive DSLR quality pictures and cinematic Full HD movies using the 18.0 Megapixel EOS 1300D. Share instantly using Wi-Fi and connect to your smart device by simply using NFC. -
Take distinctive photos that set you apart
Capture superb detailed images thanks to a large 18.0 Megapixel APS-C size sensor. Print your images up to A2 size or creatively crop them and still achieve great quality. -
Natural low light shots
Take memorable, atmospheric pictures in low light with a large ISO sensitivity range of ISO 100-6400 (expandable to ISO 12,800), which reduces the need for flash - so you can capture the natural ambience of every precious moment. -
Beautiful background blur
Create stunning portrait shots that emphasize your subject against beautiful soft blurred backgrounds thanks to the shallow depth of field associated with DSLR photography. -
Superb detail and color
Shoot superb images with the details, colors and contrast exactly as you remember thanks to the DIGIC 4+ processor. -
Explore your creativity in movies and stills
Explore Creative filters like Toy camera and Miniature that add a different mood and unique finish to your photos. -
Cinematic Full HD movies
Shoot superbly detailed Full HD movies with a beautiful cinematic feel thanks to DSLR control depth of field, which ensures your subject is sharp while your background is beautifully blurred.
- Canon EOS 1300D - digital camera EF-S 18-55mm IS II lens
- Product Type
- Digital camera - 1080p - SLR with Live View mode, movie recording
- Lens Included
- EF-S 18-55mm IS II lens
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4+
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 18.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Lens System
- Zoom lens - 3x zoom - 18 - 55 mm - f/3.5-5.6 IS II Canon EF-S
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 25 cm
- Image Stabiliser
- Optical
- Camera Flash
- Pop-up flash
- Viewfinder
- Optical - fixed eye-level pentamirror
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E10 Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 12.9 cm x 7.76 cm x 10.13 cm
- 485 g
- Product Type
- Lens Included
- Enclosure Colour
- Black
- Sensor Resolution
- 18.0 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 18,700,000 pixels
- Effective Sensor Resolution
- 18,000,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- Frame Rate (Max Resolution)
- 30 fps
- ISO (Max)
- 12800
- Optical Zoom
- 3x
- Image Processor
- DIGIC 4+
- Image Stabiliser
- Optical
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast and phase detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Predictive AI Servo AF
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Auto Focus Features
- Predictive Focus Control
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view, Wireless Image Transfer
Exposure & White Balance
- Light Sensitivity
- ISO 12800, ISO 100-6400, ISO auto (100-6400)
- Exposure Metering
- Evaluative, partial (10%), centre-weighted
- Exposure Metering Zones
- 63
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, close-up, night portrait, food, sports mode
- Special Effects
- Neutral, fisheye, soft focus, Faithful, monochrome, landscape, portrait, miniature, Toy camera, Grainy B&W, Standard
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, Flash, daylight, shade
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±5 EV range, in 1/2 or 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/2 or 1/3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/200sec
- Exposure Range
- EV 1-20 (ISO 100)
Lens System
- Focal Length Equivalent to 35mm Camera
- 29 - 88mm
- Focus Adjustment
- Automatic, manual
- 25 cm
- Max View Angle
- 74.3 degree(s)
- Zoom Adjustment
- Manual
- Lens Construction
- 9 groups / 11 elements
- Filter Size
- 58 mm
- Lens Mounting Type
- Canon EF/EF-S
- Aspherical lens
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 9.2
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation
Additional Features
- Continuous Shooting Speed
- 3 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- RGB primary colour filter, auto power save, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, highlight tone priority, GPS ready, highlight point display, Dust Delete Data system, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Eye-Fi Card Ready, Scene Intelligent Auto technology, noise reduction over long exposures, high ISO speed noise reduction
Tripod Mount
- Connection Point
- 1/4" socket
Viewfinder
- Viewfinder Type
- Optical Viewfinder Field Coverage
- 95%
- Optical Viewfinder Magnification
- 0.8x
- Optical Viewfinder Dioptric Correction Range
- -2.5 to +0.5
- Viewfinder Information
- Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock, maximum burst, monochrome shooting
Display
- 3" LCD display
- Display Format
- 920,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output (19 pin mini HDMI Type C)
Software
- Software
- Drivers & Utilities, Canon Digital Photo Professional, Canon Picture Style Editor, Canon EOS Utility
- Included Accessories
- Battery pack, battery charger, neck strap, USB cable, eyecup, battery cover, power cable
- Body Material
- Carbon fibre/fibreglass-reinforced polycarbonate resin
- Battery Type
- Canon LP-E10 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 500 shots (at 23 °C (AE 50%, FE 50%)) , Photo shooting - 410 shots (at 0 °C (AE 50%, FE 50%))
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Image Storage
- RAW 5184 x 3456 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , JPEG 1920 x 1280 , JPEG 720 x 480
- Video Capture
- MOV - 1920 x 1080 p - 30 fps , MOV - 1920 x 1080 p - 24 fps , MOV - 1280 x 720 p - 60 fps , MOV - 1280 x 720 p - 50 fps , MOV - 640 x 480 p - 30 fps , MOV - 640 x 480 p - 25 fps
- 12.9 cm
- 7.76 cm
- 10.13 cm
- 485 g
- 0 °C
- 40 °C
- 0 - 85%
