Capture superb detailed images thanks to a large 18.0 Megapixel APS-C size sensor. Print your images up to A2 size or creatively crop them and still achieve great quality. Take memorable, atmospheric pictures in low light with a large ISO sensitivity range of ISO 100-6400 (expandable to ISO 12,800), which reduces the need for flash - so you can capture the natural ambience of every precious moment.
- Canon EOS 1300D - digital camera - body only
- Product Type
- Digital camera - 1080p - SLR with Live View mode, movie recording
- Lens Included
- Body only
- Memory Card Slot
- SD card
- Image Processor
- DIGIC 4+
- Wireless Interface
- Wi-Fi, NFC
- Sensor Resolution
- 18.0 Megapixel
- Max Video Resolution
- 1920 x 1080
- Camera Flash
- Pop-up flash
- Viewfinder
- Optical - fixed eye-level pentamirror
- Display
- LCD display - 3"
- Supported Battery
- Canon LP-E10 Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 12.9 cm x 7.76 cm x 10.13 cm
- 485 g
- Product Type
- Lens Included
- Body only
- Enclosure Colour
- Black
- Sensor Resolution
- 18.0 Megapixel
- Optical Sensor Type
- CMOS
- Total Pixels
- 18,700,000 pixels
- Effective Sensor Resolution
- 18,000,000 pixels
- Optical Sensor Size
- APS-C (22.3 x 14.9 mm)
- Field of View Crop Factor
- 1.6
- Frame Rate (Max Resolution)
- 30 fps
- ISO (Max)
- 12800
- Image Processor
- DIGIC 4+
- Face Detection
- Print Standard
- Direct print, DPOF support, Exif Print support, PictBridge support
- Auto Focus
- TTL contrast and phase detection
- Auto Focus Points (Zones) Qty
- 9
- AE/AF Control
- Predictive AI Servo AF
- Digital Video Format
- H.264, MOV
- Image Recording Format
- JPEG, RAW, RAW + JPEG
- 1920 x 1080
- Auto Focus Features
- Predictive Focus Control
- Interface
- Composite video/audio, HDMI, USB 2.0, IEEE 802.11b/g/n, NFC (Near Field Communication)
- Computer Connectivity
- Mac, Windows
- Connectivity Features
- Remote control via mobile devices, remote live view, Wireless Image Transfer
Exposure & White Balance
- Light Sensitivity
- ISO 12800, ISO 100-6400, ISO auto (100-6400)
- Exposure Metering
- Evaluative, partial (10%), centre-weighted
- Exposure Metering Zones
- 63
- Exposure Modes
- Programme, bulb, automatic, manual, aperture-priority, shutter-priority
- Shooting Programs
- Landscape, portrait mode, close-up, night portrait, food, sports mode
- Special Effects
- Neutral, fisheye, soft focus, Faithful, monochrome, landscape, portrait, miniature, Toy camera, Grainy B&W, Standard
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Fluorescent, cloudy, tungsten light, Flash, daylight, shade
- Max Shutter Speed
- 1/4000 sec
- Min Shutter Speed
- 30 sec
- Exposure Compensation
- ±5 EV range, in 1/2 or 1/3 EV steps
- Auto Exposure Bracketing
- 3 steps in 1/2 or 1/3 EV steps
- White Balance Bracketing
- X-sync Speed
- 1/200sec
- Exposure Range
- EV 1-20 (ISO 100)
Lens System
- Lens Mounting Type
- Canon EF/EF-S
Camera Flash
- Camera Flash
- Pop-up flash
- Guide Number (m / ISO 100)
- 9.2
- Flash Modes
- Fill-in mode, auto mode, flash OFF mode, red-eye reduction
- Red-Eye Reduction
- AF illuminator, flash +/- compensation
Additional Features
- Continuous Shooting Speed
- 3 frames per second
- Self-Timer Delay
- 10 sec, 2sec
- Flash Terminal
- Hot shoe
- Additional Features
- RGB primary colour filter, auto power save, depth-of-field preview button, digital image rotation, camera orientation detection, histogram display, AE lock, AF lock, FE lock, highlight tone priority, GPS ready, highlight point display, Dust Delete Data system, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Eye-Fi Card Ready, Scene Intelligent Auto technology, noise reduction over long exposures, high ISO speed noise reduction
Tripod Mount
- Connection Point
- 1/4" socket
Viewfinder
- Viewfinder Type
- Optical Viewfinder Field Coverage
- 95%
- Optical Viewfinder Magnification
- 0.8x
- Optical Viewfinder Dioptric Correction Range
- -2.5 to +0.5
- Viewfinder Information
- Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status, FE lock, maximum burst, monochrome shooting
Display
- 3" LCD display
- Display Format
- 920,000 pixels
- Display Form Factor
- Built-in
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0 , Composite video/audio output , HDMI output (19 pin mini HDMI Type C)
Software
- Software
- Drivers & Utilities, Canon Digital Photo Professional, Canon Picture Style Editor, Canon EOS Utility
- Included Accessories
- Battery pack, battery charger, neck strap, USB cable, eyecup, battery cover, power cable
- Body Material
- Carbon fibre/fibreglass-reinforced polycarbonate resin
- Battery Type
- Canon LP-E10 Lithium Ion
- Details
- Battery Life Details
- Photo shooting - 500 shots (at 23 °C (AE 50%, FE 50%)) , Photo shooting - 410 shots (at 0 °C (AE 50%, FE 50%))
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card Included
- No
- Image Storage
- RAW 5184 x 3456 , JPEG 5184 x 3456 , JPEG 3456 x 2304 , JPEG 2592 x 1728 , JPEG 1920 x 1280 , JPEG 720 x 480
- Video Capture
- MOV - 1920 x 1080 p - 30 fps , MOV - 1920 x 1080 p - 24 fps , MOV - 1280 x 720 p - 60 fps , MOV - 1280 x 720 p - 50 fps , MOV - 640 x 480 p - 30 fps , MOV - 640 x 480 p - 25 fps
- 12.9 cm
- 7.76 cm
- 10.13 cm
- 485 g
- 0 °C
- 40 °C
- 0 - 85%
