Canon EOS 1100D - Digital camera - SLR - 12.0 Mpix body only - black
Canon EOS 1100D Digital SLR
Quicklinx: 7TVKWS00 Mfr#: 5161B016AA
  • SDHC Memory Card
Advanced, compact and affordable: your first steps into the world of DSLR photography, made simple with Canon EOS 1100D.
  • 12-megapixel resolution
    Step up to DSLR image quality with a 12-megapixel APS-C-sized sensor. A 14-bit DIGIC 4 image processor provides 3.2fps continuous shooting and images that are packed with detail and tonal range.
  • Intuitive, on-screen feature guide
    The EOS 1100D's feature guide provides descriptions of many of the camera's functions, as well as advice on how to use them in your own photography.
  • Easy to use Scene modes and Basic+
    Theme-based Scene modes automatically pick the most suitable exposure, focus and drive-mode settings for the subject being photographed, while Creative Auto mode portrays adjustable functions in an easy to understand way. With Canon's Basic + technology, the look and feel of these basic auto modes can be fine-tuned according to ambience and lighting type.
  • HD EOS movie mode
    Shoot stunning HD video at 25 or 30 fps, with automatic exposure control leaving you free to concentrate on the action. Footage can be edited on your PC or Mac, or played directly on an HD TV via the camera's HDMI connection.
  • ISO 100-6400 sensitivity
    Low-light shooting without flash is possible thanks to the EOS 1100D's ISO 100-6400 sensitivity range. The camera's 14-bit DIGIC 4 processor helps to control noise and maintain image quality.
  • Wide-area 9-point AF system
    The EOS 1100D focuses quickly and accurately on static and moving subjects, thanks to nine AF points, spread out across the frame. A central cross-type AF point is sensitive to both horizontal and vertical lines.
  • 63-zone iFCL exposure metering
    Advanced iFCL exposure metering dissects a scene into 63-zones before analyzing it to find the perfect combination of shutter speed, aperture and ISO.
  • 6.8 cm, 230,000-dot LCD screen
    Compose and review images on a large 230,000-dot LCD screen, which also provides access to the camera's menu system and Quick Control Screen.
Canon EOS 1100D - digital camera - body only
Digital camera - 720p - SLR with Live View mode, movie recording
Lens Included
Body only
Memory Card Slot
SD card
Image Processor
DIGIC 4
Sensor Resolution
12.0 Megapixel
Max Video Resolution
1280 x 720
Camera Flash
Pop-up flash
Viewfinder
Optical - eye-level mirror pentaprism
Display
LCD display - 2.7"
Supported Battery
Li-ion rechargeable battery (included)
Composite video/audio, HDMI, USB 2.0
Microsoft Certification
Compatible with Windows 7
13 cm x 7.8 cm x 10 cm
495 g
Lens Included
Body only
Enclosure Colour
Sensor Resolution
12.0 Megapixel
Optical Sensor Type
CMOS
Total Pixels
12,600,000 pixels
Effective Sensor Resolution
12,000,000 pixels
Optical Sensor Size
APS-C (22.2 x 14.7 mm)
Field of View Crop Factor
1.6
ISO (Max)
6400
Image Processor
DIGIC 4
Face Detection
Print Standard
Direct print, DPOF support, Exif Print support, PictBridge support
Auto Focus
TTL phase detection
Auto Focus Points (Zones) Qty
9
Digital Video Format
H.264, MOV
Image Recording Format
JPEG, RAW, RAW + JPEG
1280 x 720
Exposure & White Balance
Light Sensitivity
ISO 100-6400, ISO auto (100-6400)
Exposure Metering
Evaluative, partial (10%), centre-weighted
Exposure Metering Zones
63
Exposure Modes
Programme, depth-of-field, bulb, automatic, manual, aperture-priority, shutter-priority
Shooting Programs
Landscape, portrait mode, close-up, night portrait, sports mode
Special Effects
Neutral, Faithful, monochrome, landscape, portrait
White Balance
Custom, automatic, presets
White Balance Presets
Fluorescent, cloudy, tungsten light, Flash, daylight, shade
Max Shutter Speed
1/4000 sec
Min Shutter Speed
30 sec
Exposure Compensation
±5 EV range, in 1/2 or 1/3 EV steps
Auto Exposure Bracketing
3 steps in 1/2 or 1/3 EV steps
White Balance Bracketing
X-sync Speed
1/200sec
Exposure Range
EV 1-20 (ISO 100)
Lens System
Lens Mounting Type
Canon EF/EF-S
Camera Flash
Camera Flash
Pop-up flash
Guide Number (m / ISO 100)
9.2
Flash Modes
Fill-in mode, rear curtain sync, auto mode, flash OFF mode, red-eye reduction
Red-Eye Reduction
AF illuminator, flash +/- compensation
Additional Features
Continuous Shooting Speed
2 frames per second, 3 frames per second
Self-Timer Delay
10 sec, 2sec
Flash Terminal
Hot shoe
Additional Features
RGB primary colour filter, auto power save, digital noise reduction, depth-of-field preview button, histogram display, AE lock, AF lock, FE lock, highlight tone priority, LCD live view mode, highlight point display, Dust Delete Data system, built-in help guide, Auto Lighting Optimizer, peripheral illumination correction, Eye-Fi Card Ready
Viewfinder
Viewfinder Type
Optical Viewfinder Field Coverage
95%
Optical Viewfinder Magnification
0.8x
Optical Viewfinder Dioptric Correction Range
-2.5 to +0.5
Viewfinder Frames
Autofocus frame
Viewfinder Information
Shutter speed, exposure compensation, AE lock, AF-in-focus, flash charge completion, red-eye reduction, aperture, white balance, high-speed sync indicator, flash compensation on/off, highlight tone priority, ISO sensitivity, memory card status
Display
2.7" LCD display
Display Format
230,400 pixels
Display Form Factor
Built-in
Display Features
Display brightness control
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0 , Composite video/audio output , HDMI output , Remote control
Software
Software
Drivers & Utilities, Canon PhotoStitch, Canon ZoomBrowser EX, Canon ImageBrowser, Canon Remote Capture, Canon Digital Photo Professional, Canon Picture Style Editor
Battery charger, body cap, neck strap, USB cable, eyecup, audio / video cable
Body Material
Stainless steel, polycarbonate resin
Battery Type
Canon LP-E10 Lithium Ion
Details
Memory / Storage
Memory Card Slot
SD card
Supported Memory Cards
SD Memory Card, SDXC Memory Card, SDHC Memory Card
Image Storage
RAW 4272 x 2848 , JPEG 4272 x 2848 , JPEG 3088 x 2056 , JPEG 2256 x 1504 , JPEG 1920 x 1280 , JPEG 720 x 480
Video Capture
MOV - 1280 x 720 - 30 fps , MOV - 1280 x 720 - 25 fps
13 cm
7.8 cm
10 cm
495 g
