Canon EF-S 18-55mm f/3.5-5.6 IS II Lens
Quicklinx: 824NWS00 Mfr#: 5121B005AA
Type: Lens
11 In Stock
£157.88 ex VAT
£189.45 inc VAT
Compact and affordable, the EF-S 18-55 mm f/3.5-5.6 IS II is an ideal general-purpose standard zoom. Its four-stop image stabilizer provides great performance in low-light conditions.
The EF-S 18-55 mm f/3.5-5.6 IS II is a high-quality, standard zoom lens that will appeal to photographers who prefer to travel light. With a focal length equivalent of 29-88 mm in 35 mm format, the lens' wide zoom range is suitable for most general photography. For close-up work, the working distance is just 0.25 m throughout the zoom range.
  • Affordable, high-quality zoom
  • Image Stabilizer (IS)
    To minimize risk of image blur, the EF-S 18-55 mm f/3.5-5.6 IS II incorporates Canon's four-stop Image Stabilizer (IS) technology. This allows photographers to use shutter speeds up to four times slower than normal with no perceptible increase in image blur - ideal for shooting in low light.
  • Aspherical lens element with super spectra coating
    As well as ensuring true color balance and sharp, high contrast images, super spectra coatings combat ghosting and flare by absorbing light reflecting off digital camera sensors or internal lens elements. An aspherical lens element delivers crisp, high contrast images - even with the aperture fully open.
  • Circular aperture
    For shots taken at wide apertures, a circular aperture diaphragm gives a smooth, even blur to your background, helping to emphasize foreground subjects and remove distractions.
  • Lead-free glass
    Only environmentally-friendly, lead-free glass is used in the construction of the EF-S 18-55 mm f/3.5-5.6 IS II.
Canon EF-S zoom lens - 18 mm - 55 mm
Lens System
Zoom lens
Intended For
Digital SLR, full-frame digital SLR
Mounting Type
Canon EF/EF-S
Lens Aperture
F/3.5-5.6
Focal Length
18 mm - 55 mm
Optical Zoom
3 x
Min Focus Distance
25 cm
Focus Adjustment
Automatic, manual
Lens Construction
9 groups / 11 elements
Special Functions
Zoom
Filter Size
58 mm
Length
7 cm
200 g
Length
7 cm
Diameter
6.9 cm
200 g
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Focal Length
18 mm - 55 mm
Lens Aperture
F/3.5-5.6
Minimum Aperture
F/22 - f/38
Focal Length Equivalent to 35mm Camera
29 - 88mm
Optical Zoom
3 x
Magnification
0.34
Image Stabiliser
Optical
Min Focus Distance
25 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
64.5 degree(s)
Min View Angle
27.8 degree(s)
Lens Construction
Filter Size
58 mm
Diaphragm Blades
6
Lens Coating
Super Spectra coating
Mounting Type
Canon EF/EF-S
Aspherical lens
Dust cap, lens cap
824N Canon Filter - protection - 58 mm In Stock £24.19
Type: Lens
Brand: Canon
