Canon EF-S 17-55mm f/2.8 IS USM
Change your view. Not your aperture.
With a constant f/2.8 aperture throughout the zoom range and a 3-stop Image Stabilizer, the EF-S 17-55mm f/2.8 IS USM provides outstanding performance and framing flexibility in low light conditions.
- Wide angle zoom for EF-S mount bodies
- f/2.8 aperture throughout zoom range
- 3-stop Image Stabilizer
- Fast, quiet auto focus
- Super Spectra coating
- Circular aperture for pleasing background blur
- Passes distance information to E-TTL II
- Optional lens hood
High performance wide angle zoom
With an effective focal length range of approximately 27-88mm (35 mm equivalent), the EF-S 17-55mm f/2.8 IS USM is a powerful lens that delivers remarkable image quality. The wide angle zoom allows you to capture more of every scene and adds a new sense of space and perspective to your photography.
Fixed aperture
The large f/2.8 aperture provides excellent results in low light conditions. The aperture remains constant through the full focal length range, allowing you to zoom from approximately 27-88mm (35 mm equivalent) without slowing shutter speed.
Pleasing background blur
A circular aperture provides a pleasing background blur when shooting with a wide aperture; ideal for creating a sense of depth and isolating your subject from the background.
Image Stabilizer
The EF-S 17-55mm f/2.8 IS USM features Canon's 3-stop Image Stabilizer (IS). Ideal for handheld work, IS allows the use of shutter speeds up to 3 stops slower then normal with no perceptible increase in image blur. The IS function helps with low light conditions, fast paced scenes and shooting from moving vehicles.
A ring USM (Ultrasonic motor) uses ultrasonic frequency vibrations to drive responsive, near-silent high speed auto focus. Full time manual focus override is available without having to switch out of AF.
Super Spectra coatings
Optimised Super Spectra lens coatings and lens element shaping suppress flare and ghosting - more prone to occur with digital cameras due to reflection off the image sensor. Coatings also help achieve true colour balance and increase contrast for vivid high definition images.
The lens passes distance information back to the camera's E-TTL II flash system to ensure optimal flash metering in any shooting situation.
- Canon EF-S zoom lens - 17 mm - 55 mm
- Lens System
- Zoom lens
- Intended For
- Digital SLR, full-frame digital SLR
- Mounting Type
- Canon EF/EF-S
- Lens Aperture
- F/2.8
- Focal Length
- 17 mm - 55 mm
- Optical Zoom
- 3.2 x
- Min Focus Distance
- 35 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 12 groups / 19 elements
- Special Functions
- Zoom
- Filter Size
- 77 mm
- Length
- 11.1 cm
- 645 g
- 1-year warranty
- Designed For
- EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
- Length
- 11.1 cm
- Diameter
- 8.4 cm
- 645 g
Lens System
- Zoom lens
- Special Functions
- Zoom
- Intended For
- Focal Length
- 17 mm - 55 mm
- Lens Aperture
- F/2.8
- Optical Zoom
- 3.2 x
- Image Stabiliser
- Optical
- 35 cm
- Focus Adjustment
- Automatic, manual
- Zoom Adjustment
- Manual
- Max View Angle
- 78.5 degree(s)
- Min View Angle
- 27.8 degree(s)
- Lens Construction
- Filter Size
- 77 mm
- Mounting Type
- Canon EF/EF-S
- UD glass, Ultrasonic Motor (USM), full-time manual focusing, aspherical lens
- Included Accessories
- Lens cap
- Limited warranty - 1 year
- Designed For
- Canon EOS 1000D, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Canon EW-83J - lens hood | In Stock | £33.33 |
