Canon EF 70-300mm f/4-5.6 IS II USM Lens
Quicklinx: D67MWS00 Mfr#: 0571C005AA
Close in on the action with the EF 70 - 300 mm IS II USM telephoto zoom lens. With a wide zoom range and fast, near-silent autofocus, it can be ideal for anyone, looking to capture distant subjects. Equipped with NANO USM technology, it quickly focuses, so you're able to get the exact moment you want, as it happens. This technology also helps provide ultra-quiet operation while video recording to help ensure the only audio you hear is what you intended to keep. While you're setting up that ideal shot, the lens information display provides a convenient way to check focal length, focus distance or depth of field with just a quick glance. If you find yourself without a tripod and unable to keep the camera perfectly steady, built-in image stabilization will help keep your images as clear as possible despite camera movement. Inside, the EF 70-300 mm IS II USM has an optimally-placed UD lens element, which helps produce high-contrast and high-detail images, while reducing chromatic aberrations. Combining a wide zoom range with fast autofocus and high-quality optics, the EF 70 - 300 mm IS II USM is perfect for photographers, looking to expand their lens possibilities with a fast and powerful telephoto zoom lens.
Canon EF telephoto zoom lens - 70 mm - 300 mm
Lens System
Telephoto zoom lens
Intended For
Digital SLR, full-frame digital SLR
Mounting Type
Canon EF
Lens Aperture
F/4.0-5.6
Focal Length
70 mm - 300 mm
Optical Zoom
4.3 x
Min Focus Distance
1.2 m
Focus Adjustment
Automatic, manual
Lens Construction
12 groups / 17 elements
Special Functions
Tele, zoom
Filter Size
67 mm
Length
14.55 cm
710 g
Length
14.55 cm
Diameter
8 cm
710 g
Lens System
Telephoto zoom lens
Special Functions
Tele, zoom
Intended For
Focal Length
70 mm - 300 mm
Lens Aperture
F/4.0-5.6
Optical Zoom
4.3 x
Image Stabiliser
Optical
Min Focus Distance
1.2 m
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual (by ring)
Max View Angle
34 degree(s)
Min View Angle
8.25 degree(s)
Lens Construction
Filter Size
67 mm
Diaphragm Blades
9
Mounting Type
Canon EF
UD glass, internal focusing system, full-time manual focusing, rear focusing system, NANO USM technology, LCD information display
Dust cap, lens cap
