Canon EF 50mm f/1.4 USM
The ultimate mixture of versatility and image quality.
With its fast maximum aperture and rapid focusing system, the compact, high performance EF 50mm f/1.4 USM standard lens can be relied on for superb performance in any field of photography.
- Fast f/1.4 aperture
- Standard 46° angle of view
- USM focus motor with full-time manual focus override
- 45cm closest focusing distance
- Aspherical lens element
- 58mm filter size
Versatile, compact standard-lens design
Gaussian optics, combined with two high-refraction lens elements allow photographers working in all fields to capture crisp, clean images, even wide open at f/1.4. The lens is ideal for photographing landscapes and travel scenes as well as portraits and reportage.
Ultrasonic focusing
A ultrasonic motor drives autofocus extremely quickly, and in near silence. Excellent holding torque ensures the point of focus is reached accurately, without overshooting. Furthermore, full-time manual override is available, making it possible to adjust focus without leaving AF mode.
Smooth background blur
A virtually circular aperture diaphragm gives out of focus regions a softer, more uniform feel. Sharp foreground objects stand out against a smooth blurred background.
Super Spectra coating
Super Spectra coatings ensure accurate colour balance and enhance contrast. They also reduce flare and ghosting - a common problem caused by light bouncing off a camera's sensor.
- Canon EF lens - 50 mm
- Lens System
- Lens
- Intended For
- Digital SLR, full-frame digital SLR
- Mounting Type
- Canon EF
- Lens Aperture
- F/1.4
- Focal Length
- 50 mm
- Min Focus Distance
- 45 cm
- Focus Adjustment
- Automatic, manual
- Lens Construction
- 6 groups / 7 elements
- Filter Size
- 58 mm
- Length
- 5.1 cm
- 290 g
- Designed For
- EOS 1000D, 1D, 1Ds, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
- Length
- 5.1 cm
- Diameter
- 7.4 cm
- 290 g
Lens System
- Lens
- Intended For
- Focal Length
- 50 mm
- Lens Aperture
- F/1.4
- Minimum Aperture
- F/22
- Magnification
- 0.15
- 45 cm
- Focus Adjustment
- Automatic, manual
- Max View Angle
- 46 degree(s)
- Lens Construction
- Filter Size
- 58 mm
- Diaphragm Blades
- 8
- Mounting Type
- Canon EF
- Ultrasonic Motor (USM), full-time manual focusing
- Included Accessories
- Dust cap, lens cap
- Designed For
- Canon EOS 1000D, 1D, 1D Mark II, 1D Mark II N, 1D Mark III, 1D Mark IV, 1Ds, 1Ds Mark II, 1Ds Mark III, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 5D Mark II, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Canon Filter - protection - 58 mm | In Stock | £24.19 |
