Canon EF 24-70mm f/2.8L II USM Lens
Quicklinx: 8XB8WS00 Mfr#: 5175B005AA
Type: Lens
Hurry, only 1 left in stock!
£1,599.99 ex VAT
£1,919.98 inc VAT
Express delivery Delivered on Tuesday
A professional-quality standard zoom offers superlative image quality and a fast f/2.8 maximum aperture throughout its zoom range. It is perfect companion to any full-frame EOS camera.
The EF 24-70 mm f/2.8L II USM delivers superb image quality throughout its zoom range, thanks to aspherical lens elements and ultra-low dispersion (UD) and super UD glass. Redesigned optics ensures sharpness is maximized across the frame.
A fast f/2.8 maximum aperture is maintained throughout the zoom range, enabling hand-held low-light shooting in a variety of situations. The EF 24-70 mm f/2.8L II USM is robust enough for daily professional use. Weather sealing protects against dust and moisture, while a fluorine-coated front and rear elements are easy to clean.
  • Next-generation optical design
  • Versatile 24-70 mm zoom range
    The ideal companion is designed for any full-frame EOS camera. It is perfect for applications ranging from landscape and travel photography to portraiture and photojournalism.
  • Shoot in low light conditions
  • L-series build quality
  • USM autofocus
    Aring-type ultrasonic AF motor achieves focus quickly, quietly and accurately. Full-time manual override is available, making it possible to adjust focus without changing focus modes.
  • Close focusing
    A 0.38 m closest-focus distance adds to the versatility of the EF 24-70 mm f/2.8L II USM, providing a maximum magnification of 0.21x.
  • Beautiful background blur
    A nine-bladed circular aperture provides superb bokeh, ideal for portraiture.
  • Area of use
    A versatile standard zoom lens is designed for any professional photographer.
Canon EF zoom lens - 24 mm - 70 mm
Lens System
Zoom lens
Intended For
Digital SLR
Mounting Type
Canon EF
Lens Aperture
F/2.8
Focal Length
24 mm - 70 mm
Optical Zoom
2.9 x
Min Focus Distance
38 cm
Focus Adjustment
Automatic, manual
Lens Construction
13 groups / 18 elements
Special Functions
Zoom
Filter Size
82 mm
Length
11.3 cm
0.81 kg
Length
11.3 cm
Diameter
8.9 cm
0.81 kg
Lens System
Zoom lens
Special Functions
Zoom
Intended For
Digital SLR
Focal Length
24 mm - 70 mm
Lens Aperture
F/2.8
Optical Zoom
2.9 x
Magnification
0.21
Min Focus Distance
38 cm
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
84 degree(s)
Min View Angle
34 degree(s)
Lens Construction
Filter Size
82 mm
Diaphragm Blades
9
Lens Coating
Fluorine coating
Mounting Type
Canon EF
UD glass, internal focusing system, Ultrasonic Motor (USM), full-time manual focusing, aspherical lens
Lens hood, dust cap, lens cap, carrying pouch
Type: Lens
Brand: Canon
Price Range Ex VAT: £1500+
Stock Status: While stocks last
Stock Status: Clearance
