Canon EF - Telephoto zoom lens - 70 mm - 200 mm - f/2.8 L USM - Canon EF
Quicklinx: 5B3JWS00 Mfr#: 2569A018AA
Type: Lens
£1,284.09 ex VAT
£1,540.90 inc VAT
This large aperture, super high image quality telephoto zoom lens provides performance comparable to that of a single focal length lens, with a wide zoom range. This lens is developed as a successor to the EF 80-200mm f/2.8L. Its major features include: a ring USM (Ultrasonic Motor) drive, built-in full-time manual focusing, short minimum focusing distance of 1.5m, high marginal illumination, and compatibility with Extenders EF1.4X and EF2X (extends the zoom range with AF to 98-280mm f/4 or 140-400mm f/5.6 respectively). Although this is a large aperture telephoto zoom lens, it is equipped with four low refraction/low dispersion UD (Ultra-low Dispersion) glass lens elements (2nd, 3rd, 11th & 13th) that offer excellent contrast and sharpness. This is a lens that deserves to be known as a super high performance telephoto zoom lens.
Canon EF telephoto zoom lens - 70 mm - 200 mm
Lens System
Telephoto zoom lens
Intended For
Digital SLR
Mounting Type
Canon EF
Lens Aperture
F/2.8
Focal Length
70 mm - 200 mm
Optical Zoom
2.9 x
Min Focus Distance
1.5 m
Focus Adjustment
Automatic, manual
Lens Construction
15 groups / 18 elements
Special Functions
Tele
Filter Size
77 mm
Length
19.4 cm
1.31 kg
EOS 1000D, 1D, 1Ds, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Length
19.4 cm
Diameter
8.5 cm
1.31 kg
Lens System
Telephoto zoom lens
Special Functions
Tele
Intended For
Digital SLR
Focal Length
70 mm - 200 mm
Lens Aperture
F/2.8
Minimum Aperture
F/32
Optical Zoom
2.9 x
Magnification
0.16
Min Focus Distance
1.5 m
Focus Adjustment
Automatic, manual
Zoom Adjustment
Manual
Max View Angle
34 degree(s)
Min View Angle
12 degree(s)
Lens Construction
Filter Size
77 mm
Diaphragm Blades
8
Lens Coating
Multicoated
Mounting Type
Canon EF
UD glass, internal focusing system, Ultrasonic Motor (USM), full-time manual focusing
Lens hood, dust cap, lens cap
Canon EOS 1000D, 1D, 1D Mark II, 1D Mark II N, 1D Mark III, 1D Mark IV, 1Ds, 1Ds Mark II, 1Ds Mark III, 20D, 20Da, 300D, 30D, 350D, 400D, 40D, 450D, 500D, 50D, 5D, 5D Mark II, 7D, Digital Rebel, Digital Rebel XT, Digital Rebel XTi, Kiss Digital, Kiss Digital N, Kiss Digital X, Kiss F, Kiss X2, Kiss X3, Rebel T1i, Rebel XS, Rebel XSi
Type: Lens
Brand: Canon
Price Range Ex VAT: £1000 - £1500
