Canon DR-M260 Document Scanner
Quicklinx: D7SFWS00 Mfr#: 2405C003
Type: Document scanner
Form Factor: Desktop
Max Paper Size: 216 x 5588 mm
Interface: USB 3.1 Gen 1
Compatibility: PC
  • Windows 8.1 (32/64 bits)
£480.93 ex VAT
£577.11 inc VAT
The compact imageFORMULA DR-M260 has a small frame, yet produces a big performance. This dependable scanner is packed with innovative features and delivers outstanding image quality, with capture speeds of up to 60 ppm/120 ipm.
Canon imageFORMULA DR-M260 - document scanner - desktop - USB 3.1 Gen 1
Document scanner - desktop
Interface Type
USB 3.1 Gen 1
Scanning Sensor Type
CMOS / CIS
Light Source
RGB LED array
Max Supported Document Size
216 x 5588 mm
Input Type
Grayscale / Color Depth
8-bit (256 grey levels) / 24-bit (16.7 million colours)
Optical Resolution
600 dpi x 600 dpi
Max Document Scan Speed
60 ppm (mono) / 60 ppm (colour)
Max Document Size
216 mm x 5588 mm
Automatic Duplexing
Supported Document Type
Plain paper, business card, passport, post card
Document Storage Capacity
80 sheets
Duty Cycle
7500 scans per day
Microsoft Windows 7 (32/64 bits) SP1, Microsoft Windows Server 2008 R2 (32/64-bits), Windows 8.1 (32/64 bits), Windows 10 (32/64 bits), Microsoft Windows Server 2012 R2 (32/64 bits), Microsoft Windows Server 2016 (32/64 bits)
28.5 cm x 17.8 cm x 18 cm
3.6 kg
2 Years
Interface Type
USB 3.1 Gen 1
216 x 5588 mm
Scanner
Input Type
Grayscale Depth
Colour Depth
Optical Resolution
600 dpi x 600 dpi
Automatic Duplexing
CMOS / CIS
Bulb / Light Source Type
RGB LED array
Max Document Scan Speed B/W
60 ppm
Max Document Scan Speed Colour
60 ppm
Duty Cycle
7500 scans per day
Scanner Speed Details
60 ppm - black & white , 60 ppm - colour
Scanner Features
Color Dropout, Ultrasonic Double Feed Detection, Error Diffusion, Moire Reduction, automatic colour detection, automatic page size detection, blank page skipping, built-in LCD screen, MultiStream Technology, Advanced Text Enhancement, Text Orientation Recognition, Batch Separation, automatic resolution setting, Smooth Background, 3 Dimensional Color Correction processing, Advanced Text Enhancement II, Prevent Bleed Through, Remove Background, Double Feed Release (DFR), Character Emphasis, Shadow Cropping, Deskew, Color Enhancement, Adjustable Gamma Settings, Black-and-White Contrast, Full Auto Mode, Folio Mode
TWAIN, ISIS
Media Handling
Max Document Size
216 mm x 5588 mm
80 sheets
USB 3.1 Gen 1
USB cable
Power Consumption Operational (Standby)
23 Watt
Power Consumption Sleep
1.4 Watt
Software Included
Drivers & Utilities, Canon CapturePerfect, Kofax VirtualReScan, Canon CaptureOnTouch
28.5 cm
17.8 cm
18 cm
3.6 kg
Service and Support
2 years
Compatibility: PC
Brand: Canon
