The LEGRIA HF R26 is an ideal companion if you're new to Full HD video. Features a Canon Full HD CMOS sensor, 28x advanced zoom, touch-screen and intelligent smart auto for superb results every time.
3.2MP Full HD CMOS sensor
The Full HD 3.2MP CMOS sensor gives true HD quality and excellent color reproduction even in low light, so your movies will look great on your HDTV. Capture high-resolution 3.0MP still photos at the touch of a button. -
Fingertip control
Operation is easy with a high-resolution 7.5cm (3.0") gesture-based touch-screen LCD, which gives you intuitive fingertip control of settings and simplifies playback. -
28x advanced zoom
A genuine Canon HD video lens with 28x advanced zoom lets you get close to even far away subjects. -
8GB dual Flash memory
A 8GB dual Flash memory lets you store over 3 hours of movies to the built-in memory. Record even longer with two SDXC card slots or upload wirelessly with an Eye-Fi card. Relay recording automatically switches cards if one becomes full. Copy between memory cards and convert movies from HD to SD in camera for really easy sharing and web uploading. -
Smart auto with tele-macro
Effortlessly shoot high quality video with smart auto. Intelligent Scene Detection technology selects the perfect settings from 38 scene modes - all you have to do is point and shoot. Shoot extreme close ups with auto tele-macro mode. -
Dynamic image stabilizer
Canon's dynamic electronic image stabilizer ensures all your movies have a smooth professional look even when shooting while walking. Easily switch between dynamic and standard mode. -
Fun touch decoration
Add fun effects to your movies without a PC using touch decoration. Write messages straight on the touch-screen with the stylus pen, add stamps or active animations like shooting stars and mix in still images. -
Top-quality action videos
The LEGRIA HF R26 records Full HD quality at a fast maximum bit rate of 24Mbps so you're sure of top-quality footage of fast moving subjects - perfect for action videos. -
Fun, short movies
With video snapshot it's easy to create fun movies to share with friends - without a PC. Capture 2, 4 or 8 second clips with just one touch of the record button, create a playlist, add music and your movie is ready. -
Precise focusing
Face detection automatically optimizes settings for perfectly focused people shots.
- Canon LEGRIA HF R26 - Value-up Kit - camcorder - storage: flash card
- Product Type
- Camcorder - 1080p
- Media Type
- Flash card
- Memory Card Slot
- SD card
- Image Processor
- DIGIC DV III
- Sensor Resolution
- 3.28 MP
- Effective Sensor Resolution
- Video: 2.07 MP - Photo: 3.05 MP
- Lens System
- Zoom lens - 20x zoom - 3 - 60 mm - f/1.8-3.6
- Focus Adjustment
- Automatic, manual
- Min Focus Distance
- 1 cm
- Digital Zoom
- 400x
- Image Stabiliser
- Electronic
- Display
- LCD display - 3"
- Supported Battery
- Li-ion rechargeable battery (included)
- Interface
- Composite video/audio, HDMI, USB 2.0
- Black
- 6 cm x 12.1 cm x 6.2 cm
- 270 g
- Product Type
- Camcorder - 1080p
- Enclosure Colour
- Black
- Camcorder Type
- Consumer
- Camcorder Sensor Resolution
- 3.28 MP
- Sensor Qty
- 1 CMOS
- Effective Video Resolution
- 2.07 MP
- Effective Photo Resolution
- 3.05 MP
- Widescreen Video Capture
- Camcorder Media Type
- Flash card
- Optical Sensor Type
- CMOS
- Optical Sensor Size
- 1/4.85"
- Optical Zoom
- 20x
- Digital Zoom
- 400x
- Video Recording Modes
- SP, LP, FXP, MXP, XP+
- Image Processor
- DIGIC DV III
- Faders
- Wipe fader, black & white fader, sepia fader
- Image Stabiliser
- Electronic
- Face Detection
- Surround Sound
- Dolby Digital AC-3 (2 channel) recording
- Auto Focus
- TTL contrast detection
- Digital Video Format
- AVCHD
- Image Recording Format
- JPEG
- Interface
Exposure & White Balance
- Exposure Modes
- Programme, automatic, aperture-priority, shutter-priority
- Shooting Programs
- Spotlight, portrait mode, night mode, fireworks, low light, sports mode, sunset, beach, snow
- Special Effects
- Black & White, Sepia
- White Balance
- Custom, automatic, presets
- White Balance Presets
- Daylight, artificial light
- Max Shutter Speed
- 1/2000 sec
- Min Shutter Speed
- 1/2 sec
Lens System
- Focal Length Equivalent to 35mm Camera
- 41.2 - 1154mm
- Focus Adjustment
- Automatic, manual
- 1 cm
- Zoom Adjustment
- Motorised drive
- Filter Size
- 34 mm
- Built-in lens shield
Additional Features
- Self-Timer Delay
- 10 sec
- Low Lux / Night Mode
- Additional Features
- Built-in speaker, RGB primary colour filter, Gesture User Interface, Pre-Rec function, relay recording, Video Snapshot mode, HD-to-SD downconversion, face detection, 25p Cinema Mode, auto backlight compensation, x.v.Colour technology, Touch Decoration
Display
- 3" LCD display
- Display Format
- 230,000 pixels
- Display Form Factor
- Rotating
- Touch Screen
- Display Features
- Display brightness control
Microphone
- Microphone Operation Mode
- Stereo
- Connector Type
- Component video output , Composite video/audio output , HDMI output , USB 2.0 , Headphones
Software
- Software
- Drivers & Utilities, Pixela Video Browser, Pixela Transfer Utility
- Included Accessories
- Power adapter, USB cable, HDMI cable
- Battery Type
- Canon BP-110 Lithium Ion
- Run Time (Up To)
- 1.5 hour(s)
- Details
Memory / Storage
- Memory Card Slot
- SD card
- Supported Memory Cards
- SD Memory Card, SDXC Memory Card, SDHC Memory Card
- Memory Card
- 4 GB SDHC
- Image Storage
- JPEG 1920 x 1080 , JPEG 1792 x 1344 , JPEG 2016 x 1512
- Video Capture
- AVCHD - 1920 x 1080 - 24Mbps - require SDHC Class 4 or higher , AVCHD - 1920 x 1080 - 17Mbps - require SDHC Class 4 or higher , 1440 x 1080 - 12Mbps , 1440 x 1080 - 7Mbps , 1440 x 1080 - 5Mbps
- 6 cm
- 12.1 cm
- 6.2 cm
- 270 g
