Canon CanoScan LiDE 300 - Flatbed scanner - A4/Letter
Quicklinx: FV3NWS00 Mfr#: 2995C010
Type: Flatbed scanner
Form Factor: Desktop
Max Paper Size: 216 x 297 mm
Interface: USB 2.0
Compatibility: Mac, PC
Select:
More than 50 In Stock
£45.32 ex VAT
£54.38 inc VAT
Compact and affordable, this lightweight scanner is perfect for those wanting straightforward scanning at the touch of a button.
  • Compact, sleek and affordable scanner for home or office
    With a sleek, compact and stylish design, this lightweight A4 flatbed scanner is fitted with 4 EZ operation buttons for easy use and hassle-free scanning. Perfect for high-resolution scanning at home or in the office.
  • Pristine borderless prints
    Effortlessly print stunning borderless photos from 4x6 inch to A4, filled with fine detail and documents with sharp text for high-quality results.
  • Instant access
    Enjoy straightforward printing, copying and scanning using your smartphone or tablet or directly access cloud storage via PIXMA Cloud Link - all thanks to the Canon PRINT app.
  • Freedom of the cloud
    Print and scan documents to cloud services such as GoogleDrive, OneDrive and Dropbox. You can also attach and send scanned files directly via email - all without a PC.
  • Maximize your money
    Cut waste and boost your cost savings by up to 50% compared to standard cartridges with optional XL ink cartridges and auto 2-sided printing.
  • Get creative
    Unleash your inner artist with Creative Park and the Easy PhotoPrint Editor. Use the app to design cards, calendars and more using photos from your tablet, PC or cloud.
Canon CanoScan LiDE 300 - flatbed scanner - desktop - USB 2.0
Flatbed scanner - desktop
Interface Type
USB 2.0
Scanning Sensor Type
Contact Image Sensor (CIS)
Light Source
3-colour RGB LED
Additional Functions
Scan to cloud
Max Supported Document Size
216 x 297 mm
Input Type
Grayscale / Color Depth
16-bit (64K grey levels) / 48-bit colour
Grayscale / Color Depth (External)
8-bit (256 grey levels) / 48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
Interpolated Resolution
19200 dpi
Max Document Size
216 mm x 297 mm
Supported Document Type
Plain paper, bulk objects (such as books, magazines and other bound materials)
Microsoft Windows 7, Microsoft Windows 7 SP1, Windows 8.1, Windows 10, Apple MacOS X 10.11.6, Apple macOS 10.12 - 10.13
25 cm x 36.7 cm x 4.2 cm
1.7 kg
2-year Limited Warranty
Interface Type
USB 2.0
Scan to cloud
216 x 297 mm
Scanner
Input Type
Grayscale Depth
Grayscale Depth (External)
Colour Depth
48-bit colour
Colour Depth (External)
48-bit colour
Optical Resolution
2400 dpi x 2400 dpi
19200 dpi
Bulb / Light Source Type
3-colour RGB LED
Control Panel Buttons Functions
Copy, AutoScan, send to, PDF
Scanner Speed Details
10 sec/scan - colour - A4 - 300 dpi , 5 sec/scan - colour - 4x6 - 300 dpi , 9 sec/scan - preview , 14.8 ms/line - colour - 2400 dpi , 6.6 ms/line - colour - 1200 dpi , 3.8 ms/line - colour - 600 dpi , 2.2 ms/line - colour - 300 dpi , 4.3 ms/line - greyscale - 2400 dpi , 2.2 ms/line - greyscale - 1200 dpi , 1.3 ms/line - greyscale - 600 dpi , 2.2 ms/line - greyscale - 300 dpi
Scanner Features
Auto Document Fix, Auto Scan Mode, Auto Photo Fix, 4 EZ Buttons, Advanced Z-lid Expansion Top
Media Handling
Max Document Size
216 mm x 297 mm
USB 2.0 - Mini-B
1 x USB cable
Power Consumption Operational (Standby)
4.5 Watt
Power Consumption Stand by
0.3 Watt
Software Included
Drivers & Utilities
25 cm
36.7 cm
4.2 cm
1.7 kg
5 °C
35 °C
10 - 90% (non-condensing)
Interface: USB 2.0
Compatibility: Mac
Compatibility: PC
Brand: Canon
