Canon A4 Colour Printer\s18ppm Colour 1200 x 1200 dpi Multi
Quicklinx: HQX7WS00 Mfr#: 5158C017
£213.79 ex VAT
£256.54 inc VAT
Durable A4 color multi-function printers connected to the cloud for streamlined printing and scanning.
  • Maximize print and scan productivity with connected color printers
    Extensive connectivity to the cloud and mobile enables easy document access from anywhere, while streamlined workflows make efficient work of everyday tasks.
  • Access files from the cloud
    Out-of-the-box cloud connectivity is compatible with Google Drive, DropBox, and OneDrive, making it quick and easy to print and scan directly to and from the cloud.
  • Automate everyday tasks
    Customize your workflows with the Application Library, which enables one-touch tasks such as printing stored forms, scanning to email, and copying documents.
  • Protect sensitive documents
    Robust security features include Secure PIN to restrict jobs being automatically released and verify system at startup to protect your device from hacking and virus threats.
  • Increase efficiency
    Fast printing, time-saving single-pass double-sided scanning, and a large color touchscreen facilitate efficient print and scan workflows.
Canon i-SENSYS MF651Cw - multifunction printer - colour
Multifunction printer
Printing Technology
Laser (colour)
Monthly Duty Cycle (max)
30000 pages
Recommended Monthly Volume
250 - 2500 pages
Max Copying Speed
Up to 18 ppm (mono) / up to 18 ppm (colour)
Max Copying Resolution
Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
Max Printing Speed
Max Printing Resolution
Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
Scanning
600 x 600 dpi
Display
5"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Media Size
76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
Media Type
Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards, coloured paper
Standard Media Capacity
250 sheets
Output Trays Capacity
100 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
AirPrint Enabled
Office Machine Features
Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host
AC 230 V (50/60Hz)
45.1 cm x 46 cm x 36 cm
18.9 kg
Printing Technology
Laser - colour
30000 pages
250 - 2500 pages
Display Diagonal Size
5"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Standard Memory
1 GB
Copying
Max Copying Speed
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
999
Exposure Modes
Text, text / photo / map
Automatic Duplexing
Copying Features
Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
Max Printing Speed
Printer Drivers / Emulations
PDF, TIFF, UFRII, JPEG
First Print Out Time B/W
10.4 sec
First Print Out Time Colour
10.5 sec
Scanning
Optical Resolution
600 x 600 dpi
Interpolated Resolution
9600 x 9600 dpi
Colour Depth
24-bit
Colour Depth (Internal)
24-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
Original Type
Sheets
Min Media Size
76.2 x 127 mm
Max Media Size
A4/Legal
Min Media Weight
60 g/m²
Max Media Weight
200 g/m²
Supported Media Type
Supported Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
250 sheets
100 sheets
Paper cassette - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Bypass tray size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Output tray - 100 sheets
Speed Details
Printing: up to 18 ppm (A4) , Copying: up to 18 ppm (A4) , Scanning: up to 27 ipm - B/W , Scanning: up to 14 ppm - colour , Printing: up to 38 ppm (A5)
1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
Security Protocols & Features
Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering, SNMP 3
Operating System Support
Linux, Android, iOS, Windows 8.1, Windows 10, Apple Mac OS X 10.11 or later, Windows 11, MS Windows Server 2022
Software Included
Drivers & Utilities, iW Management Console
AC 230 V (50/60Hz)
370 Watt
Power Consumption Standby
11 Watt
Power Consumption Sleep
0.8 Watt
Warm-Up Time
13 sec
First Copy Out Time B/W
11.4 sec
First Copy Out Time Colour
13.4 sec
Consumables Included
1 x toner cartridge (black) - up to 1350 pages - Canon 067 , 1 x toner cartridge (black) - up to 3130 pages - Canon 067H , 1 x toner cartridge (cyan) - up to 1250 pages - Canon 067 , 1 x toner cartridge (cyan) - up to 2350 pages - Canon 067H , 1 x toner cartridge (magenta) - up to 1250 pages - Canon 067 , 1 x toner cartridge (magenta) - up to 2350 pages - Canon 067H , 1 x toner cartridge (yellow) - up to 1250 pages - Canon 067 , 1 x toner cartridge (yellow) - up to 2350 pages - Canon 067H
45.1 cm
46 cm
36 cm
18.9 kg
Sound Emission
64 dB (operating)
10 °C
30 °C
20 - 80% RH (non-condensing)
HQX7 Canon 067 H - High capacity - black In Stock £74.94
HQX7 Canon 067 H - High capacity - cyan In Stock £77.39
HQX7 Canon 067 H - High capacity - magenta In Stock £77.42
Brand: Canon
