Durable A4 color multi-function printers connected to the cloud for streamlined printing and scanning.
Maximize print and scan productivity with connected color printers
Extensive connectivity to the cloud and mobile enables easy document access from anywhere, while streamlined workflows make efficient work of everyday tasks. -
Access files from the cloud
Out-of-the-box cloud connectivity is compatible with Google Drive, DropBox, and OneDrive, making it quick and easy to print and scan directly to and from the cloud. -
Automate everyday tasks
Customize your workflows with the Application Library, which enables one-touch tasks such as printing stored forms, scanning to email, and copying documents. -
Protect sensitive documents
Robust security features include Secure PIN to restrict jobs being automatically released and verify system at startup to protect your device from hacking and virus threats. -
Increase efficiency
Fast printing, time-saving single-pass double-sided scanning, and a large color touchscreen facilitate efficient print and scan workflows.
- Canon i-SENSYS MF651Cw - multifunction printer - colour
- Multifunction printer
- Printing Technology
- Laser (colour)
- Monthly Duty Cycle (max)
- 30000 pages
- Recommended Monthly Volume
- 250 - 2500 pages
- Max Copying Speed
- Up to 18 ppm (mono) / up to 18 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Scanning
- 600 x 600 dpi
- Display
- 5"
- Original Size
- A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Media Size
- 76.2 x 127 mm (min) - Legal (216 x 356 mm), A4 (210 x 297 mm) (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, heavy-weight paper, thin paper, glossy paper, postcards, coloured paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 100 sheets
- Automatic Duplexing
- Yes (copying)
- Connection Availability
- Interface
- USB 2.0, Gigabit LAN, Wi-Fi(n), USB host
- AirPrint Enabled
- Office Machine Features
- Print from USB flash drive, scan to e-mail, scan to Cloud, scan to FTP, scan to PC, scan to USB host
- Power
- AC 230 V (50/60Hz)
- 45.1 cm x 46 cm x 36 cm
- 18.9 kg
- 2-year warranty
- Laser - colour
- 30000 pages
- 250 - 2500 pages
- Display Diagonal Size
- 5"
- Display Colour Support
- Display Features
- Touch screen
- Interface
- AirPrint Enabled
- Standard Memory
- 1 GB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 999
- Exposure Modes
- Text, text / photo / map
- Copying Features
- Toner Save, 2 on 1, 4 on 1, ID Card Copy, Frame Erase Copy, collation copy
Printing
- Printer Drivers / Emulations
- PDF, TIFF, UFRII, JPEG
- First Print Out Time B/W
- 10.4 sec
- First Print Out Time Colour
- 10.5 sec
Scanning
- Optical Resolution
- 600 x 600 dpi
- Interpolated Resolution
- 9600 x 9600 dpi
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 24-bit
Document & Media Handling
- Max Original Size
- Supported Original Sizes
- Original Type
- Sheets
- Min Media Size
- 76.2 x 127 mm
- Max Media Size
- A4/Legal
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 200 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm), 76.2 x 127 mm, Oficio (216 x 343 mm), Foolscap (216 x 343 mm)
- Supported Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), Monarch (98.4 x 190.5 mm)
- 250 sheets
- 100 sheets
- Paper cassette - 250 sheets size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Bypass tray size: 76.2 x 127 mm - Legal (216 x 356 mm)/A4 (210 x 297 mm) weight: 60 g/m² - 200 g/m² , Output tray - 100 sheets
- Speed Details
- Printing: up to 18 ppm (A4) , Copying: up to 18 ppm (A4) , Scanning: up to 27 ipm - B/W , Scanning: up to 14 ppm - colour , Printing: up to 38 ppm (A5)
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45 , 1 x USB host - 4 pin USB Type A
- Secure Print, SSL, WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, IP filtering, MAC address filtering, SNMP 3
- Operating System Support
- Linux, Android, iOS, Windows 8.1, Windows 10, Apple Mac OS X 10.11 or later, Windows 11, MS Windows Server 2022
- Software Included
- Drivers & Utilities, iW Management Console
- Voltage Required
- 370 Watt
- Power Consumption Standby
- 11 Watt
- Power Consumption Sleep
- 0.8 Watt
- Warm-Up Time
- 13 sec
- First Copy Out Time B/W
- 11.4 sec
- First Copy Out Time Colour
- 13.4 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 1350 pages - Canon 067 , 1 x toner cartridge (black) - up to 3130 pages - Canon 067H , 1 x toner cartridge (cyan) - up to 1250 pages - Canon 067 , 1 x toner cartridge (cyan) - up to 2350 pages - Canon 067H , 1 x toner cartridge (magenta) - up to 1250 pages - Canon 067 , 1 x toner cartridge (magenta) - up to 2350 pages - Canon 067H , 1 x toner cartridge (yellow) - up to 1250 pages - Canon 067 , 1 x toner cartridge (yellow) - up to 2350 pages - Canon 067H
- Limited warranty - 2 years
- 45.1 cm
- 46 cm
- 36 cm
- 18.9 kg
- Sound Emission
- 64 dB (operating)
- 10 °C
- 30 °C
- 20 - 80% RH (non-condensing)
Canon 067 H - High capacity - black | In Stock | £71.34 |
Canon 067 H - High capacity - cyan | In Stock | £73.56 |
Canon 067 H - High capacity - magenta | In Stock | £73.56 |
