Focused on vibrant color photo printing, versatility, and usability, the Canon PIXMA PRO-200 is the ideal choice for photo enthusiasts and aspiring photographers.
Impressive high-quality photographs
With a superior 8-color dye-based ink system, you're guaranteed exceptional reproduction, richer colors, and vibrant professional printing, every time. -
Pick paper that suits you
With versatile media handling and customisable printing sizes, you can enhance your photographs on a variety of paper including fine art, borderless and panoramic. -
Quick and easy to use
The built-in 3-inch LCD display lets you check ink levels, perform printer maintenance, and access printer instructions at a glance - for excellent results with ease. -
Perfect printing every time
With 3 paper feed options and auto paper skew correction function, you can bid farewell to misalignment and printing fails, no matter what paper you're using. -
One seamless process
Canon's user-friendly PPL (Professional Print & Layout) software means you can shoot and send photos with ease from popular photography programs for a one-stop edit-to-print experience. -
Compact and lightweight
Even with A3+ paper capabilities, Canon PIXMA PRO-200 remains a lightweight solution for your printing needs. And it's compact too, so fits easily into a small studio. -
For faster, more efficient printing
Great shots happen in a flash, and so does great printing. Canon PIXMA PRO-200 is fast and efficient, delivering exceptional quality A3+ printouts in just 90 seconds, giving you more time to find the next great shot.
- Canon PIXMA PRO-200 - printer - colour - ink-jet
- Printer Type
- Photo printer - ink-jet - colour
- 14.1 kg
- Inkjet Technology
- Canon FINE (Full-lithography inkjet Nozzle Engineering)
- Ink Palette Supported (Colours)
- 8-ink
- Max Media Size
- A3 Plus (329 x 483 mm)
- Min Media Size (Custom)
- 89 mm x 127 mm
- Max Media Size (Custom)
- 329 mm x 990.6 mm
- Print Speed
- Up to 1.5 min/page - photo - A3 plus (329 x 423 mm)
- Max Resolution (Colour)
- 4800 x 2400 dpi
- Interface
- USB 2.0, LAN, Wi-Fi(n)
- AirPrint Enabled
- Preview Screen Size
- 3"
- Media Type
- Envelopes, plain paper, iron-on transfers, photo paper, fine art paper, DVD discs, CD discs, BD discs, nail stickers
- Total Media Capacity
- 100 sheets
- Media Handling
- CD/DVD tray, 100-sheet input tray, 1-sheet manual tray
- Networking
- Print server
- Printer Features
- Borderless printing
- Power
- AC 120/230 V
- System Requirements
- Windows 10 Mobile
- 63.9 cm x 37.9 cm x 20 cm
- Printer Type
Printer
- Inkjet Technology
- 8-ink
- Nozzle Configuration
- 6144 nozzles
- Ink Cartridge Configuration
- 8 individual ink tanks
- Ink Type
- Canon ChromaLife100+
- Print Speed
- Built-in Devices
- LCD display
- 3"
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 4800 x 2400 dpi
- Direct Printing Specifications
- PictBridge
- Printer Features
- Media Handling
Media Handling
- Media Type
- Max Media Size
- 89 mm x 127 mm
- 329 mm x 990.6 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A3 (297 x 420 mm), B4 (250 x 353 mm), ANSI B (Ledger) (279 x 432 mm), Panoramic A2 (210 x 594 mm), 100 x 148 mm, 101.6 x 152.4 mm, CD (120 mm), 88.9 x 127 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 304.8 x 304.8 mm, A3 Plus (329 x 483 mm), 254 x 304.8 mm, 177.8 x 254 mm, 329 x 990.6 mm
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), Panoramic A2 (210 x 594 mm), 100 x 148 mm, 101.6 x 152.4 mm, 88.9 x 127 mm, 127 x 127 mm, 127 x 177.8 mm, 203.2 x 254 mm, 304.8 x 304.8 mm, A3 Plus (329 x 483 mm), 254 x 304.8 mm, 177.8 x 254 mm
- Envelope Sizes
- International DL (110 x 220 mm), Com-10 (105 x 241 mm)
- Media Weight
- 64 g/m² - 380 g/m²
- 100 sheets
- Media Feeders
- Input tray: 1 x automatic - 100 sheets - A3 Plus (329 x 483 mm) weight: 64 g/m² - 380 g/m² , 1 x manual - 1 sheet - A3 Plus (329 x 483 mm) 380 g/m² , 1 x automatic - CD (120 mm)
- Networking
- Print server
- Remote Management Protocol
- SNMP, HTTP, IPv4, IPv6
- WEP, WPA-PSK, 802.1x, WPA2-PSK, TKIP, AES, EAP-TTLS, EAP-TLS, PEAP
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 8 x ink tank
- PIXMA Cloud Link
- Power Device
- Power supply
- Voltage Required
- AC 120/230 V
- Frequency Required
- 50/60 Hz
- 1.6 Watt
- Power Consumption Stand by
- 1 Watt
- Software Included
- Drivers & Utilities
- OS Required
- Windows 10 Mobile
- Sound Emission (Operating)
- 42.5 dB
- 63.9 cm
- 37.9 cm
- 20 cm
- 14.1 kg
Canon CLI65Y Yellow Ink Cart | In Stock | £14.04 |
Canon CLI-65 GY - Grey - original - ink tank - for PIXMA PRO | In Stock | £14.04 |
Canon 4216C001 CLI65C Cyan Ink Cart 13ML | In Stock | £14.04 |
Canon 4222C001 LT Grey Ink Cartridge 13M | In Stock | £14.04 |
Canon Photo Magenta Ink Tank | In Stock | £14.04 |
Canon Photo Cyan Ink Tank | In Stock | £14.04 |
Canon 4215C001 CLI65BK Black Ink 13ML | In Stock | £14.04 |
