Canon  TS9550a A3/A4 Colour MFP
Quicklinx: HRKQWS00 Mfr#: 2988C038
23 In Stock
£162.67 ex VAT
£195.20 inc VAT
Marketing description is not available.
  • Versatile connectivity
    With options like AirPrint, Google Cloud Print, and Wi-Fi(n), the Canon PIXMA TS9550A ensures you can print how you want, from any device. Its comprehensive connectivity options, including LAN and USB 2.0, make it a perfect fit for any modern workspace.
  • High-quality copying
    The device offers a range of copying features such as 2 on 1, 4 on 1, and Borderless copy, alongside more specialized options like ID Card Copy and disc label copy. With a first copy out time of just 19 seconds and a max copying speed of 6.5 ppm, it's designed to enhance productivity.
  • Advanced media handling
    Supporting a wide array of media sizes and types, from envelopes and photo paper to A3 size and CD/DVDs, the Canon PIXMA TS9550A is equipped to handle diverse printing needs. Its automatic document feeder and dual paper cassettes offer convenience and efficiency.
  • Intuitive interface
    A 4.3" touchscreen display makes navigating the printer's numerous functions and settings a breeze, offering a user-friendly experience that complements its advanced capabilities.
  • Exceptional printing quality
    With a maximum color resolution of 4800 x 1200 DPI and the ability to print in vibrant color or crisp black and white, the Canon PIXMA TS9550A delivers professional-grade prints every time. Its automatic duplexing feature also supports eco-friendly practices by reducing paper use.
Canon PIXMA TS9550A - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
Canon FINE (Full-lithography inkjet Nozzle Engineering) - 5-ink
Max Copying Speed
6.5 ppm (colour)
Max Printing Speed
Up to 15 ipm (mono) / up to 10 ipm (colour)
Max Printing Resolution
4800 x 1200 dpi (colour)
Scanning
1200 x 2400 dpi
Display
4.3"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
55 x 89 mm (min) - CD (120 mm), 215.9 x 676 mm (max)
Media Type
Printable CD/DVD/BD disk, plain paper, glossy paper, luster paper, semi-gloss paper, matte paper, envelopes, fine art paper, photo stickers, photo paper
Standard Media Capacity
200 sheets
Automatic Duplexing
Yes (printing)
Connection Availability
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
Office Machine Features
PIXMA Cloud Link, access point mode
AC 100-240 V (50/60Hz)
46.8 cm x 36.6 cm x 19.3 cm
9.7 kg
Enclosure Colour
Printing Technology
Ink-jet - colour
Display Diagonal Size
4.3"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Enclosure Colour
Supported Flash Memory
SD Memory Card, SDHC Memory Card, SDXC Memory Card
Copying
Max Copying Speed
6.5 ppm (colour)
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Borderless copy, 2 on 1, 4 on 1, Frame Erase Copy, disc label copy, ID Card Copy, fit to page
Printing
Inkjet Technology
Max Printing Speed
Ink Cartridge Configuration
5 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black, pigment black
5-ink
Ink Type
Canon ChromaLife100
Automatic Duplexing
Scanning
Scan Element
CIS
Optical Resolution
1200 x 2400 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
A4 (210 x 297 mm), Legal (216 x 356 mm), 216 x 297 mm, ANSI A (Letter) (216 x 279 mm), A3 (297 x 420 mm)
Original Type
Sheets
20 sheets
Min Media Size
55 x 89 mm
Max Media Size
A3
Min Media Weight
64 g/m²
Max Media Weight
300 g/m²
Supported Media Type
Supported Media Sizes
A3 (297 x 420 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 200 x 250 mm, 130 x 180 mm, 130 x 130 mm, 100 x 150 mm, 89 x 89 mm, 100 x 100 mm, 175 x 250 mm, 250 x 300 mm, 300 x 300 mm, 55 x 89 mm, 215.9 x 676 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
Borderless Photo Sizes
A3 (297 x 420 mm), A4 (210 x 297 mm), ANSI A (Letter) (216 x 279 mm), 200 x 250 mm, 130 x 180 mm, 100 x 150 mm, 130 x 130 mm, 89 x 89 mm, 100 x 100 mm, 175 x 250 mm, 250 x 300 mm, 300 x 300 mm
200 sheets
Input tray - 100 sheets size: 55 x 89 mm - 215.9 x 676 mm weight: 64 g/m² - 300 g/m² , Paper cassette - 100 sheets size: 148 x 210 mm - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m² , CD/DVD/BD tray , ADF - 20 sheets
Speed Details
Printing: up to 15 ipm - B/W , Printing: up to 10 ipm - colour , Printing: 12 sec (10 x 15 cm (4"x6")) - photo , Copying: up to 6.5 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Security Protocols & Features
WEP, WPA-PSK, WPA2-PSK
Operating System Support
Windows 10, Windows 8.1, MS Windows 7 SP1, Apple Mac OS X 10.10.5 - 10.11, macOS 10.12 - macOS 10.13, Android, iOS, Windows 10 Mobile
Software Included
Drivers & Utilities, Canon PRINT App
14 Watt
Power Consumption Standby
2 Watt
Direct Printing Specifications
PictBridge
First Copy Out Time Colour
19 sec
Consumables Included
1 x ink tank (pigmented black) , 1 x ink tank (black) , 1 x ink tank (cyan) , 1 x ink tank (magenta) , 1 x ink tank (yellow)
46.8 cm
36.6 cm
19.3 cm
9.7 kg
Sound Emission
49.5 dBA (operating)
15 °C
30 °C
10 - 80% (non-condensing)
HRKQ Canon CLI581XLM Magenta Ink Cartridge In Stock £11.69
HRKQ Canon CLI-581BK Black Ink Cartridge In Stock £8.57
HRKQ Canon INK CLI-581Y XL Ink Tank - Yellow In Stock £11.69
HRKQ Canon CLI-581C XL Ink Tank - Cyan In Stock £11.69
HRKQ Canon CLI-581 XL Black Cartridge up to 2280 pages In Stock £11.69
HRKQ Canon PGI-580PGBK XXL - 25.7 ml - XXL size - black - original - in In Stock £17.37
HRKQ Canon PGI-580/CLI-581 Multi Pack - 5-pack In Stock £40.70
Type: Printer / copier / scanner
Functionality: Copier
Functionality: Printer
Functionality: Scanner
Max Paper Size: CD (120 mm)
Max Paper Size: 215.9 x 676 mm
Brand: Canon
