Canon  MAXIFY GX6550 Ink Tank Multifunction Printer
Quicklinx: HYZYWS00 Mfr#: 6351C008
Type: Printer / copier / scanner
Functionality: Scanner, Printer, Copier
Max Paper Size: 216 x 1200 mm
13 In Stock
£412.68 ex VAT
£495.21 inc VAT
This compact 3-in-1 printer with front-loading ADF is designed to provide excellent productivity even in limited spaces. Experience huge page yields and low running costs thanks to refillable ink tanks.
  • Compact size - huge business potential
    Ideal for smaller workspaces, this front-accessible 3-in-1 printer produces business-quality documents quickly.
  • Leading from the front
    Operate the printer entirely from the front thanks to its front-loading duplex 35-sheet ADF with translucent tray, ideal for confined spaces such as under counters or desks.
  • Simple, fast card scanning
    Scan ID cards and small documents quickly and easily with a smart design that removes the need to fully open the scanner.
  • Low costs that stay low
    Keep printing costs down with huge yields of 14,000 pages from a set of color ink bottles or 6,000 pages from a black ink bottle. Switch to Economy mode for even greater savings.
  • Durable double-sided documents
    Print stand-out documents at speeds of 24 ipm in black and 15.5 ipm in color. Pigment-based inks deliver documents that are marker, friction and water resistant.
  • Compact yet highly capable
    Make light work of busy schedules with a 2.7" color LCD touch screen, 250 sheet cassette and 100 sheet rear feed. Handle diverse media - even print banners up to 1.2m in length.
  • Get connected
    Print and connect to the cloud via the Canon PRINT app. Compatible with Apple AirPrint (iOS) and Mopria (Android), enhanced network security everything safe and secure.
Canon MAXIFY GX6550 - multifunction printer - colour
Multifunction printer
Printing Technology
Ink-jet (colour)
Inkjet Technology
4-ink
Refillable Tank
Monthly Duty Cycle (max)
45000 pages
Max Printing Speed
Up to 24 ipm (mono) / up to 15.5 ipm (colour)
Max Printing Resolution
Up to 600 x 1200 dpi (mono) / up to 600 x 1200 dpi (colour)
Scanning
1200 x 1200 dpi
Display
2.7"
Original Size
A4 (210 x 297 mm), Legal (216 x 356 mm) (max)
Original Type
Sheets
Document Feeder Capacity
50 sheets
Media Size
216 x 1200 mm (max)
Media Type
Plain paper, coloured paper, luster paper, glossy photo paper, matte photo paper, high resolution paper, envelopes, cards, card stock, semi-gloss photo paper, magnetic photo paper, matte paper
Standard Media Capacity
350 sheets
Automatic Duplexing
Yes (printing) Yes (scanning)
Connection Availability
Wi-Fi(ac), LAN, USB host, USB 2.0
AirPrint Enabled
Intelligent Assistant
Alexa
Office Machine Features
PIXMA Cloud Link, wireless direct printing
AC 120/230 V (50/60Hz)
39.9 cm x 41 cm x 25.4 cm
11.5 kg
Printing Technology
Ink-jet - colour
45000 pages
Display Diagonal Size
2.7"
Display Colour Support
Display Features
Touch screen
AirPrint Enabled
Copying
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Copying Features
Two-sided copy, 2 on 1, 4 on 1, collation copy, Frame Erase Copy, ID Card Copy, fit to page
Printing
Refillable Tank
Max Printing Speed
Ink Cartridge Configuration
4 individual ink tanks
Ink Palette Supported (Colours)
Cyan, magenta, yellow, black
4-ink
Automatic Duplexing
First Print Out Time B/W
7 sec
First Print Out Time Colour
8 sec
Colour Management Features
Mopria
Scanning
Scan Element
CIS
Automatic Duplexing
Optical Resolution
1200 x 1200 dpi
Grayscale Depth
8-bit
Colour Depth
8-bit
Colour Depth (Internal)
16-bit
Document & Media Handling
Max Original Size
Supported Original Sizes
127 x 127 mm, A5 (148 x 210 mm), A6 (105 x 148 mm), ANSI A (Letter) (216 x 279 mm)/Legal (216 x 356 mm), B5 (176 x 250 mm)
Original Type
Sheets
50 sheets
Max Media Size
A4/Legal
Min Media Weight
64 g/m²
Max Media Weight
265 g/m²
Supported Media Type
Supported Media Sizes
A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B5 (176 x 250 mm), ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), 100 x 150 mm, 130 x 180 mm, 180 x 250 mm, 200 x 250 mm, 127 x 127 mm, 89 x 127 mm, 216 x 1200 mm, 216 x 297 mm
Supported Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm)
350 sheets
Input tray - 100 sheets - 216 x 1200 mm weight: 64 g/m² - 265 g/m² , Paper cassette - 250 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) weight: 64 g/m² - 105 g/m² , ADF - 50 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm) , DADF - 35 sheets - Letter A (216 x 279 mm)/A4 (210 x 297 mm)
Speed Details
Printing: up to 24 ipm - B/W , Printing: up to 15.5 ipm - colour
1 x USB 2.0 - 4 pin USB Type B , 1 x USB host - 4 pin USB Type A , 1 x LAN - RJ-45
Security Protocols & Features
WPA-PSK, WPA2-PSK, WPA3-SAE, WPA-EAP, WPA2-EAP, WPA3-EAP, TKIP, AES, 802.1x, EAP-TLS, EAP-TTLS, PEAP
Operating System Support
Windows 11, Windows 10, Windows 8.1, MS Windows 7 SP1, MS Windows Server 2008 R2 SP1, MS Windows Server 2012 R2, MS Windows Server 2016, MS Windows Server 2019, MS Windows Server 2022, macOS 10.15, macOS 11, macOS 12 Monterey, macOS 13, Chrome OS, iOS, iPadOS, Android
Software Included
Drivers & Utilities, Canon PRINT Inkjet/SELPHY, Canon Easy-PhotoPrint Editor, Canon Creative Park
24 Watt
Power Consumption Standby
0.9 Watt
Internet of Things (IoT)
Alexa
Consumables Included
1 x ink bottle (black) - Canon GI-56BK , 1 x ink bottle (cyan) - Canon GI-56C , 1 x ink bottle (magenta) - Canon GI-56M , 1 x ink bottle (yellow) - Canon GI-56Y
39.9 cm
41 cm
25.4 cm
11.5 kg
Sound Emission
49 dBA (operating)
5 °C
35 °C
10 - 90% RH (non-condensing)
Functionality: Printer
Functionality: Copier
Brand: Canon
