Canon  i-SENSYS LBP7210Cdn Colour Laser Printer
Quicklinx: 8KHHWS00 Mfr#: 6373B003
Everything small workgroups need to create high quality color print every time. This energy efficient and network ready compact color laser printer is ideal for small workgroups needing fast, professional output with productive automatic double-sided printing.
  • Performance-enhancing features
    If your small workgroup needs to share a fast and reliable printer, the LBP7210Cdn delivers everything you could want. Offering 20ppm output in both color and mono, and featuring a low profile design with a small footprint, the LBP7210Cdn represents an impressive blend of compact size and high performance.
  • Consistently inspiring results
    With up to 9600 x 600 dpi equivalent resolution with Automatic Image Refinement (AIR) as standard, the LBP7210Cdn delivers superior color quality every time. It enables you to print a wide variety of documents - like presentations, reports and professional-quality letters - in crisp color and sharp black and white.
  • Save time and be more productive
    The LBP7210Cdn offers a wide selection of features to help boost your productivity. Thanks to its Quick First-Print technologies, the LBP7210Cdn has a First Print Out Time of just 16 seconds, almost eliminating waiting times. It has a 250-sheet cassette and 50-sheet tray as standard. An additional 250-sheet cassette provides a total paper supply of 550 sheets. This means fewer interruptions and longer replenishment cycles. Productive automatic double-sided printing helps you complete print jobs, while simultaneously saving costs and producing more professional-looking documents.
  • Network ready
    Small workgroups can share productive color printing with this network ready unit. A built-in network interface maximizes flexibility and connectivity; while IT administrators will appreciate the Remote User Interface (RUI) that makes the LBP7210Cdn easier to manage and monitor over the network using standard web browsers.
  • Simple and affordable to maintain
    The all-in-one cartridge system reduces maintenance requirements and provides continuous high quality output. Simply replace the cartridge - containing toner, drum and cleaning units - and the printer is virtually as good as new. Convenient front loading enables easy, quick and clean cartridge replacement.
  • Energy-efficient operation
    With low energy consumption of just 3 watts in sleep mode and a TEC of 2.2 kWh/week, the LBP7210Cdn is among the most energy-efficient printers in its class. The Auto Shutdown Tool improves energy efficiency further.
Canon i-SENSYS LBP7210Cdn - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
22.3 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 127 mm
Max Media Size (Custom)
215.9 mm x 355.6 mm
Print Speed
Up to 20 ppm - B/W - A4 (210 x 297 mm) , Up to 20 ppm - colour - A4 (210 x 297 mm)
Max Resolution (Colour)
9600 x 600 dpi
Image Enhancement Technology
Automatic Duplexing
USB, LAN
RAM Installed (Max)
16 MB
Language Simulation
CAPT
Media Type
Envelopes, transparencies, labels, plain paper, heavy-weight paper, cards, recycled paper, coated paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet bypass tray
Monthly Duty Cycle (max)
40000 pages
Print server - Ethernet, Fast Ethernet
Linux, Apple MacOS X 10.5.x or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 R2 x64 Edition, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits)
41.4 cm x 49.9 cm x 32.8 cm
Printer Type
Printer
Print Speed
Wired
USB, LAN
9600 x 600 dpi
Automatic Duplexing
Language Simulation
CAPT
Media Handling
RAM
RAM Installed (Max)
16 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 127 mm
215.9 mm x 355.6 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), Statement (139.7 x 215.9 mm)
Envelope Sizes
International DL (110 x 220 mm), Com-10 (105 x 241 mm), International C5 (162 x 229 mm), International B5 (176 x 250 mm), Monarch (98.4 x 190.5 mm)
Media Weight
60 g/m² - 220 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m² , 1 x automatic - 50 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 220 g/m²
Output Trays Capacity
125 sheets
Duty Cycle
40000 pages
Print server
1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
Consumables Included
1 x toner cartridge (black) - up to 1200 pages - Canon 718 Starter , 1 x toner cartridge (cyan) - up to 1400 pages - Canon 718 Starter , 1 x toner cartridge (magenta) - up to 1400 pages - Canon 718 Starter , 1 x toner cartridge (yellow) - up to 1400 pages - Canon 718 Starter
Power supply - internal
Frequency Required
50/60 Hz
1170 Watt
Power Consumption Stand by / Sleep
20 Watt
Software Included
Drivers & Utilities
Environmental Standards
ENERGY STAR
10 °C
30 °C
20 - 80% (non-condensing)
Sound Emission (Operating)
52 dBA
Sound Emission (Quiet Mode)
24 dBA
41.4 cm
49.9 cm
32.8 cm
22.3 kg
8KHH C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
8KHH C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.71
8KHH C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
