Cables Direct VGA Cable HD-15 (M) to HD-15 (M) 20m Moulded - Black
Quicklinx: BQSRWS00 Mfr#: CDEX-720K
Length: 20m
26 In Stock
£19.69 ex VAT
£23.62 inc VAT
Our range on Super VGA cables are constructed using UL2919 approved 28awg triple mini coaxial and 4x 28awg conductor cables, this allows them to be used for extended distances. Triple shielded with copper braid, foil and drain wire. Our cables are designed for standard monitors and widescreen LCD’s that require DDC cable.
Cables Direct VGA cable - 20 m
VGA cable
Triple shielded coaxial
Molded, drain wire
Length
20 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
UL 2919
VGA cable
Shielding Material
Foil with copper braid
American Wire Gauge (AWG)
28
Molded, drain wire
Length
20 m
Connector
UL 2919
Length: 20m
Brand: Cables Direct
