The SVGA cable with audio is the ideal solution to connecting audio to monitors that have built in speakers or work spaces with speakers in close proximity to the monitor. This cable can also be used for equipment that uses an SVGA + 3.5mm stereo cable.
Connect one VGA connector to your computer and a 3.5mm stereo, connect the other VGA connector and 3.5mm to your monitor with speakers.
- SVGA male connectors
- Nickel plated SVGA connector
- Built in 3.5mm stereo
- Copper SVGA cores
- Black
- Cables Direct VGA / audio cable - 3 m
- VGA / audio cable
- Length
- 3 m
- Connectors
- HD-15 (VGA) - male , Mini-phone stereo 3.5 mm - male
- Black
- 1-year warranty
- VGA / audio cable
- Plated Connector
- Nickel
- Length
- 3 m
- Black
- Connectors
- 15 pin HD D-Sub (HD-15) - male , Mini-phone stereo 3.5 mm - male
- 1-year warranty
