Cables Direct VGA (D-Sub) to VGA (D-Sub) 5m Grey
Quicklinx: CRFGWS00 Mfr#: EX-025
These VGA cables are constructed using 28awg conductor cables, shielded with drain wire. The cables are designed for standard monitors and may not work with widescreen LCD’s that require DDC cable
Cables Direct VGA cable - 5 m
VGA cable
Shielded
Molded, drain wire
Length
5 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
1-year warranty
VGA cable
Shielded
American Wire Gauge (AWG)
28
Molded, drain wire
Length
5 m
Connector
1-year warranty
