Cables Direct NEWLink 30m HDMI Active Optical Cable (AOC) 18G, 4K @ 60HZ
Quicklinx: DZHYWS00 Mfr#: NLHDMI-AOC030
HDMI Active Optical Cable (AOC) use fiber optic cable to carry the HDMI signal. This means that the signal can be carried much further than a traditional copper cable and reduces the risk of interference.
HDMI AOC cables also have copper wires inside which carry the power so no external power adapter is required.
NEWlink HDMI cable - 30 m
Cable
HDMI cable
Fibre optic
Length
30 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
4K support, active cable
Cable Type
HDMI cable 4K support, active
Fibre optic
Length
30 m
HDMI CEC support (Consumer Electronics Control), HDR support, HDCP compliant, 48 bit deep colour, EMI/RFI protection, EDID compatible
Connector
19 pin HDMI Type A - male
Plug and Play, DDC
