The USB3C-HUB4BP-WPD allows you to connect four USB devices to a computer with a USB-C port (Macbook, Chromebook, etc..) The USB-C female port can charge for the host computer while the adapter is in use.
- Cables Direct USB3C-HUB4BP-WPD - hub - 4 ports
- Hub - 4 ports
- Subtype
- USB
- Ports
- 4 x SuperSpeed USB 3.0
- USB 3.0, USB 2.0
- 1-year warranty
- Hub - 4 ports
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- USB 3.0, USB 2.0
- 4 x USB 3.0 Type A , 1 x USB 3.1 Type C , 1 x USB-C (power only) Type C
- Cables Included
- 1 x USB cable - 15 cm
- Plug and Play
- Limited warranty - 1 year
