Cables Direct HDMI 4 X 4 Matrix Switch
Quicklinx: C79CWS00 Mfr#: HD-SMX404
The HD-SMX404 is a compact unit which allows you to connect the output from four High Definition sources and display them up to four HDMI display devices. For example, a set top box, DVD player and game console can be connected to four HDMI equipped displays. You can choose to duplicate outputs or have different sources on each display.
The HDMI matrix can be used as a switch, a splitter or a combination of both giving you total flexibility.
Cables Direct 4 x 4 HDMI Matrix - video/audio switch
Video/audio switch
Subtype
HDMI
HDCP compliant
1-year warranty
Video/audio switch
Enclosure Type
Desktop
Subtype
HDMI
HDCP compliant
4 x HDMI input , 4 x HDMI output , 1 x serial (RS-232) DB-9
External power adapter
Remote control
Limited warranty - 1 year
