Cables Direct DisplayPort Adapter - DisplayPort (M) to HD-15 (F) ( DisplayPort 1.1 ) - 15cm
Quicklinx: 9J0KWS00 Mfr#: HDHDPORT-VGACAB
Type: DisplayPort
Length: 15cm
More than 50 In Stock
£9.68 ex VAT
£11.61 inc VAT
DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection. Our DisplayPort to VGA adaptors are the perfect solution for adapting your DisplayPort computer or graphics card to use a VGA monitor/device.
Cables Direct DisplayPort adapter
DisplayPort adapter
Connector
DisplayPort - male
Connector (Second End)
HD-15 (VGA) - female
DisplayPort adapter
Connector
20 pin DisplayPort - male
15 pin HD D-Sub (HD-15) - female
DisplayPort 1.1
Type: DisplayPort
Length: 15cm
Brand: Cables Direct
