DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection. Our DisplayPort to VGA cables are the perfect solution for adapting your DisplayPort computer or graphics card to use a VGA monitor/device.
- Cables Direct display cable - 5 m
- Display cable
- Length
- 5 m
- Connector
- DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - male
- Display cable
- Length
- 5 m
- Connector
- 20 pin DisplayPort - male
- 15 pin HD D-Sub (HD-15) - male
- DisplayPort 1.1 / DVI 1.0
