DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection. DisplayPort to HDMI cables are the perfect solution for adapting your DisplayPort computer or graphics card to use a HDMI monitor/device/TV.
 - Cables Direct adapter cable - DisplayPort / HDMI - 5 m
- Cable
 - Adapter cable - DisplayPort / HDMI
- Length
 - 5 m
- Connector
 - DisplayPort - male
- Connector (Second End)
 - HDMI - male
 - DisplayPort 1.1
 - 24 bit deep colour
- Cable Type
 - Adapter cable
- Interface Supported
 - DisplayPort 1.1
- Length
 - 5 m
- Connector
 - 20 pin DisplayPort - male
 - 19 pin HDMI Type A - male
