Cables Direct 3m UK Plug to C5 Mains Lead - B/Q 60
Quicklinx: C8K9WS00 Mfr#: RB-290AB1-3M
The C5 to UK mains cable, more commonly know as a clover leaf lead is used for powering some laptops, mobile projectors and also can be found on the Apple iMAC G4 desktop computer and other home electrical appliances.
The PVC connectors are moulded to provide a high quality cable which is perfect for home or office use.
Cables Direct - power cable - IEC 60320 C5 to BS 1363 - 3 m
Power cable
Molded, fuse
Length
3 m
United Kingdom
Connector
Power IEC 60320 C5
Connector (Second End)
Power BS 1363 - male
Power cable
Molded, fuse
Length
3 m
United Kingdom
Connector
Power IEC 60320 C5
