Cables Direct 3m Mini DisplayPort to DVI-D M-M Cable Black - B/Q 64
Quicklinx: C8JVWS00 Mfr#: HDMINIDP-DVI-3M
Mini DisplayPort is simply a smaller version of the DisplayPort, mini DisplayPort is mainly used on MAC computers but other manufacturers may adopt this type of connector.
The mini DisplayPort to DVI adapter will allow you to connect a high definition monitor, Projector or LCD TV to a MacBook, MacBook Pro or a MacBook Air with a mini DisplayPort connection.
Please note that it has a DVI-D connector, this is for digital displays only.
Cables Direct display cable - 3 m
Display cable
Thumbscrews, passive converter
Length
3 m
Connector
Mini DisplayPort - male
Connector (Second End)
DVI-D - male
Display cable
Length
3 m
Connector
24+1 pin digital DVI - male
DisplayPort 1.1a
