Cables Direct 3m HDMI M - Micro HDMI M Cable Black
Quicklinx: CCHCWS00 Mfr#: CDLHD4-MICRO-030
Length: 3m
More than 50 In Stock
£5.03 ex VAT
£6.03 inc VAT
The CDLHD4-MICRO series has a Micro (Type D) connector that was introduced with HDMI v1.4. It keeps the standard 19 pins used in the Type A connector but shrinks it down to 2.8mm x 6.4mm. The Micro connector is to be used on mobile phones and other similar portable devices. The other side of the cable has a standard Type A connector for connecting to TVs and projectors etc.
The term HDMI v1.4 is no longer used and instead is referred to as High Speed with Ethernet.
Cables Direct HDMI cable with Ethernet - 3 m
Cable
Length
3 m
Connector
19 pin micro HDMI Type D - male
Connector (Second End)
HDMI - male
HDMI Ethernet Channel (HEC), Audio Return Channel (ARC), 3D-Transmission
Cable Type
Length
3 m
Plated Connector
Gold
Connector
19 pin HDMI Type A - male
Length: 3m
Brand: Cables Direct
