DisplayPort is a 20 pin connector similar to HDMI but designed to replace DVI/VGA. The standard was put forward by VESA to define a new royalty free audio/video connection.
DisplayPort is very simple to use and makes connecting your PC to your DisplayPort enabled display very easy. Our DisplayPort cables are black with gold flashed locking connectors to reduce disconnection due to cable strain.
 - Cables Direct DisplayPort cable - 2 m
 - DisplayPort cable
 - Lockable connector
- Length
 - 2 m
- Connector
 - DisplayPort - male
- Connector (Second End)
 - 1-year warranty
 - DisplayPort cable
- American Wire Gauge (AWG)
 - 28
- Plated Connector
 - Gold
- Length
 - 2 m
- Connector
 - 20 pin DisplayPort - male
 - 1-year warranty
